Where you able to recieve all these transponders before the move to 2G?No signal south Greece CRETE Heraklion in new transporters with 1,80 Mabo vu+ solo2
11.225 V
11.265 V
11.224 H
11.264 H
All SR and FEC of 27500 and 2/3
When the coverage map on satellite -Astra 2G - ?
Ive got a good mind to tell SES the 2G Euro beam is totally shite up here
Theres bugger all extra signal over the clapped out 28A
Well if you are getting any 2g uk beam then you are doing much better than me here in Slovakia (Near Brno) as I am getting nothing 24/7 ;)Prague, 180cm dish, 2G UK spotbeam weaker by 1.5 - 2 dB, meaning some TPs don't lock 24/7 anymore
I am aware 2G has at least two levels of Euro footprint EiRP power level, when the rate card was likely placed under the noses of the two operators of the four TP's, they've gone for the cheapest option identical to that of what E28A is currently doing. The interim illuminated 2G TP's (89 upwards etc) have a much better C/N and quality level as they have the 16MHz SES offset. I'm sure that co-channel opposing polarised TP's isn't helping, this dependant of course on crosstalk isolation of the individual LNB. I'm using an Inverto Quattro at home from a Triax TD64.Ive got a good mind to tell SES the 2G Euro beam is totally shite up here
