BBC channels frequency changes on Astra 2 due on 18/10/10
A change of transponder frequencies of the BBC services is due to take place on Monday 18 Oct.
A list of TPs affected can be found here -
_http://www.bbc.co.uk/reception/info/sat_frequencies.shtml
This will entail retuning your FTA boxes. Sky and Freesat boxes will not be affected, as the EPG will update the changes.
woborny
All down to the launch of BBC1 One HD on 3rd November - which will be on the same frequency as BBCHD currently is.
Although why not just move BBCCI and BBCEW to other frequencies, rather than move a dozen or so channels around.
Mind you, it now means that many expats can get BBC2 reception when NI and Wales move tot he verticals...!
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
could this mean,that the new spotbeam,will be activated earlier,then expected?
on the bbc site i only see the old freqencys but not the new one?
when signal then,tomorow will be more focused to uk,will be maybe use same spotbeam technic ,then on the new upcoming satellite,on this positon,in around one year from now?
There is no new spot beam, just a reshuffle of the channels on the current 2D transponders, and the addition of BBC1 HD at some point in November. The earliest chance of any sort of new spot beam at 28ºE would be if Astra 1n does go there in Q2 2011, or say if something like if 3A went there temporarily. If not the first new spot beam capacity will be Q4 2012.
Dishes: Fixed 135 cm with 2 LNB (28.2 E + 19.2 E)
Fixed 60 cm (5 W)
Motorized 120 cm
LNB: Inverto Black Ultra and others
Receivers: TBoston 4500, M3 Conax Illusion Sat, Technisat PC Skystar and others
Andalusia (Spain)
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
yep,i confirm it too ...this is a big news for BBC2 around my area
No chance of 3A slotting at 28E - she transmits in the Eurobird 1 frequencies :D
Are those frequencies fixed at launch? Or is it the sub-band that is fixed, i.e. it only receives and transmits between x & y GHz? I assumed that it worked just like a tranponder on an amateur satellite, i.e. the downlink is just a linear copy of the uplink with several hundred MHz subtracted off.
As far as I know they are fixed - SES certainly seems to indicate the satellite frequencies are fixed - the transmit downlink frequencies of each bird are available on the SES site.
However that doesnt mean some technical frequency hack isnt possible of course.
If anyone in the satellite fabrication industry knows better then Id be fascinated to know whats possible :)
It is almost certain the downlink equipment (either TWTAs or SSPAs) is fixed at manufacture as the supplier - Boeing in this case , model BSS-376HP - is built to contract for SES, and the orbital slot/ground footprint and eastimated lifetime is known before build.
Any onboard equipment that allows adjustment of footprints, frequencies or cross-strapping would add to the complexity, weight and cost of the satellite. If it deemed not necessary during planning, then it will be left out.
A small article on the budgetary analysis of communication payloads.
_http://www.communications-center.com/pdf/SBiQ499.pdf
iggy
PrimeFocus 180cm (Astra 1N) - Inverto Volksbox IDL6651n; MABO 115x128 (80E - 30W) - Dr.HD F16;
EchoStar 80cm (Hotbird + Astra) - Kathrein ufs910.
KRAKOW / POLAND
At last :) BBC2 in southern Poland, Krakow on 1,8 meter prime focus dish :) Excellent move from BBC, thank you :)
Can’t wait BBC1 in HD though
We UK Licence Fee payers aim to spread happiness ..................
Seriously though, I'm pleased this is actually benefiting "out of area" viewing.
satelliteman
Interesting to see the reception reports outside the Uk.
iggy
KRAKOW / POLAND
In Krakow there are lots of Britons who buy big dishes in order to watch their favourite Coronation Street :)
I am able to watch V polarized BBC & ITV channels using my 115/125 cm offset dish. Reception is possible throughout the day and disappears late hours until early morning.
You probably have a year before new uk spotbeams start to appear at 28E and you lose loads of stuff so make the most of it.
iggy
KRAKOW / POLAND
I already make plans for that :) Famaval 3,1 meter is within my interest. This should help I guess :)
Yeah, but it doesn't add to complexity, it makes it less complex. Having one block-convertor (something that works similar to an LNB and down converts a whole band of frequencies in one block) is much less complicated than having 18 individual pieces of hardware (single frequency down-convertors). If you use single frequency down-convertors you need to know transponder spacing, bandwidth and SR in advance and they can't be changed after launch (except SR which could be adjusted slightly).
I think the big disadvantage with block convertor though is there is no redundancy. If this one device goes down the satellite would be space junk.
Just my thoughts... nothing to do with hard facts...
Which is probably why they use individual twta's (travelling wave tube amplifiers) They are all monitored by the control uplink stations, and if telemetry starts to indicate one is going out of tolerance a spare can be remotely switched in to replace it.
Analoguesat said:
...they use individual twta's (travelling wave tube amplifiers)...
The PC brigade has been at it again.
When I were a lad they were known as Travelling Wave Amplifying Tubes with the appropriate acronym. :rolleyes:
