BBC channels frequency changes on Astra 2 due on 18/10/10
Analoguesat said:
Which is probably why they use individual twta's (travelling wave tube amplifiers)
I thought a TWTA was just a PA stage; a bit like an old radio valve.
Well a satellite is basically little more than a bent pipe in space. You fire a signal up at it, the satellite collects it, does a bit of frequency shifting and amplification then pings it back down again :D
If there's any tuning to be done, it'll be in the frequency conversion stage, well before the TWTA. Possibly switchable oscillators rather than a variable one, which could drift.
An interesting subject, there's probably more detail to be found online somewhere.
TWTA design details -
_http://www.r-type.org/static/twta.htm
PaulR said:
When I were a lad they were known as Travelling Wave Amplifying Tubes with the appropriate acronym. :rolleyes:
Don't forget the original
“Either you are with us, or you are with the terrorists, or you are not any of those things.”
~ George W. Bush on the war against terror
