I understand now, I will have a go at this today on some 26E channels. Hopefully I'll find the answer you are looking for.
Really liking the box, its just a shame that there are some flaws in the software which the Openbox never had. As previously mentioned, in the satellite menu - it moves the dish as you drill down the satellite list, rather than moving once say, the OK button is pressed. A nightmare if you're on 1W and want to get to 52E to do a TP scan. A few times this morning, ive been on 1W and from there I enter the satellite menu, as I highlight 52E from the list, the dish has moved there - fine. But then once I exit out of the menu, the dish moves back to the channel that I was on previously, in my case 1W. So there's a lot of unnecessery motor moving. Unless there's some sort of remote control combination that I need to use for it to stop doing this?
