7mdish
- Aug 11, 2013
- CM 2.4m motorised offset dish, Viking Ku-band 2-ports motorised feed, 2 SMW LNBs, RC2000A, Dreambox DM920.
- Milan, Italy
It does not seem an LNB issue. As just mentioned above, 0.3 or 0.1 is not so different, especially with a so large dish.
You must get very strong signal with 2.4m in Greece, not only on normal broadcasting transponders but also on feeds.
For example, what about the 3 main news feeds at 11043H,11050H,11056H, all SR 4937?
Obviously they are weaker than other frequencies, but what is your level in dB?
If you are not able to lock them, please check the dish pointing and the LNB focal point. Changing the LNB is time and money loosing in my opinion, other than any possible LNB fault.
