Best LNB for Astra 28.2ºE
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
samoloko
1.8 PFA
EU
New Black ultra arriving...i got 2 fresh from Germany...first tests very promising..will get back to you as soon as I do some additional tests..
Could you test on 28.2 E UK beam against older Inverto Ultra Black
Europesat
strong
Yemen
The new lnb of inverto is worse than the old ones
I'm not sure if it has been mentioned here but there are LNBs with Inverto markings out there that are not from the official factory.
shows difference after use in the field
showing the difference of the box and contents
If the LNB has not got the 'RJ' legend on the LNBF itself then you have an imposter.
Europesat
strong
Yemen
It's 100% orginal but useless
What dish are you using to compare the LNBs?
Europesat
strong
Yemen
I'm talking about the last version of inverto lnb's
stephan94
Bavaria
Here is a comparison of three LNBs.
tests from the north of Bavaria with a 1.80m antenna
all this took about 65 minutes.
Pepeyeb
Eutelsat 5 W B con antena de 1m.
Receptor de satélite Octagon SF 8008 twin. Dreambox Two.
Toledo (España)
Could you please make some more specific consideration, for which we are not experts.
Thanks.
Europesat
strong
Yemen
Comparison of inverto old black ultra and last version inverto ultra pll
Sory it's in Arabic
The first four images = old balck ultra
the scond four images = ultra with pll
  • مقارنة .pdf
weakbit
T90 Wavefrontier 5°;0,8°W-4,8°7°;9°;10°;13°;16°;19,2°;21,5°;23,6°;26°;31,5°;33;39°;42°
Vienna Austria
@stephan94 - I also have a TPS ???? Card or so but I've never have a signal like this strength. What is the program that you're using to scan the satellite? I've using a TPS program but it is not so informative if I scan with it. My scanner program is a little bit non-informative but I don't know not what for a program I shall use?
Thank you & Super nice scan what you've done!
Stay healthy and be tuned!
weakbit
stephan94
Bavaria
Good morning weakbit,
I use the program "IQMonitor pro" with a TBS 6983 card.
This program is free, but to use it well
you have to read the manual carefully and do a lot of tests.
Afterwards it is very pleasant and gives a lot of information.
To find it give" IQMonitor pro" in google , it is in a German forum
but many many texts are written in English
( but you might be Austrian, if so : kein Problem für Sie)
weakbit
Vienna Austria
@stephan94 - Danke für die Information ich habe eine TBS-6522 Karte in einem i3 und 8GB Ram. OS ist ein Windows 10pro.
LG
weakbit
Manikm909
Small'ish Dish Man
Kent, UK
I've used a twin one for 6 months and have a spare. Got them for 20 quid ea. Great lnbs
Pepeyeb
Toledo (España)
Is the LNB twin ultra better than the IBU?
Thanks.
