Advice Needed Best receiver for cccam?
Lots of receivers can work with CCCam.
If you tell us why you've narrowed your choice down to those two and what you want CCCam for, we may be able to help (Unless you propose to use a paid-for Card Share, in which case Forum Rules dictate we stop the debate forthwith).
net4hack
Triax 88 cm Dish + 4 Octogon LNBs, 2 Diseqc switches, 42" Samsung Plasma
Intel Dual Core + 2GB Ram
Dublin
Both are priced £299. I cant spend more than that . So I need a receiver that offers the best value for money.
I have a motorised dish. So could I scan for free channels from various satellites with the above?
Which one offers the best value?
Many non Linux receivers also allow entry of cccam lines as well.
At the end of the day choose the receiver that best fits what else you want it for.
net4hack
Dublin
Could you list some of them here?
At least some of the Skybox F series
I think the latest Technomate TM5402 ones do as well.
Skybox Range (Formerly Openbox), for a start.
Also, any generic DVB S Receiver should be able to scan for FTA Channels.
CCCam is not needed for that.
Edit: That lunchtime Beer has not slowed AS down any!
Yes, some non-Broadcom receivers can run CCcam but they are not even a poor relation of the receivers mentioned by the OP. None of those receivers even have a 7 day EPG that is compatible with UK TV, or auto updating channel lists.
Out of the two receivers mentioned by the OP the Solo2 is much better value for money in my opinion. And for less than half the money you could have a TM-Single, which from a user perspective you'd be hard pushed to tell the difference between it and any other single tuner E2 receiver.
net4hack
Dublin
A satellite installer just told me that AMIKO ALIEN SHD-8900 is better. Is it right?
Better in what way?
We're guessing what associated features are important to you, hence the diametrically opposed earlier replies!
Not for running E2. Completely unstable. Is he trying to sell you one?
mosllam
240 cm local motorized dish and 2 fixd 180 cm local dish with multi lnb VU+ DUO 2 yuner in use
Egypt- Cairo
one difrance i know - it might not be important to you
DM 500 HD has a tuner card as a slot in the motherboard
the solo2 has the tuner card welded to the motherboard
this is what we saw in sets that came from u.a.e - and it make a big difrance if you have to change the tuner - we did it before with a DM 800se - just pull the defected one and push the new tuner in same slot
net4hack
Dublin
Does the Solo2 has a smart card slot? If not how would I use a card?
Also would the Vu solo2 work just like a freesat stb - I have a TechniSat HD stb and a motorised dish. Would I be able to scan for free channels on various satellites using Vu solo2?
The Solo2 has two fixed DVB-S2 tuners (no welding). If you want DVB-T/T2 tuners or extra DVB-S/S2 tuners just use USB tuners. I use a Haupauge Nova-T for terrestrial, but there of plenty of other compatible USB tuners.
1 CI slot and 2 smartcard slots.
Yes, you can use it for FTA and encrypted channels. For the money you won't get a more featured, customizable and configurable box than this. And setting up can be as simple or complicated as possible. Most complaints about setting up Linux receivers come from people trying to run before they can crawl.
BTW, WoS (forum sponsor with great service and after-sales) are now doing the Solo2 for 289GBP.
net4hack
Dublin
Thanks a mil for the reply...Where to buy it - want to make sure that I dont buy a clone?
WoS = World of Satellite = Forum Sponsor
net4hack
Dublin
Thanks...Would they ship to Dublin?
Probably - you would need to check before ordering though.
I dont buy a clone?
AFAIK, there aren't any clones of that receiver yet, but to be on the safe side it's always a good idea to buy from a known source even if you have to pay a few €uro$ more.
