Broken part from linear actuator
samoloko
1.8 PFA
EU
Greetings
After 20 years my actuator tore apart - you can see from shot
Would you please advise on how to get broken part and how can I assemble again
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Was that 18" actuator? I have several parts like this, used but in better condition than yours. If you are ready to pay shipping price, I could mail you one.
samoloko
1.8 PFA
EU
Rima,
thank you very much for your help
of course I will do that
length of tube Is about 59 cm
please tell me where and what to measure
can you point to shot - what part Is broken - some nut ?
RimaNTSS
N-E from Riga
Alex! I have 3 candidates for you. All tubes are 35mm in diameter, 2 x 56cm in length and one is 42cm. If you feel one can fit, let me know.
samoloko
1.8 PFA
EU
thank you
I would like to know how can I repair original outer tube and Inner rod
how does Inner rod stay secured to outer tube In order not to fall apart as mine did
RimaNTSS
N-E from Riga
OK, when you are tired of doing that, take one (outer tube and inner rod) set from me. :cool:
And think about adding a counterweight to the dish before putting it back together.
dreambox1959
46.3N-4.3E-FRANCE
france
Greetings
we see the remains of a ball bearing !!! change it!
- sand the tubes well and repaint them
- grease the inner screw by removing it by unscrewing (no need to completely assemble the central tube) use a screwdriver to turn the central screw.
samoloko
1.8 PFA
EU
I got some progress.
Managed to remove the remaining from ball bearing - outer ring.
Now I have to order ball bearing - Inner diameter Is 10 mm , outer diameter Is 30 mm, height Is 9 mm
Would you please recommend which brand and model of ball bearing to order - I need something very reliable
Also does anyone know place where to order accordion rubber for 18 Inch actuator
