BNT World left 12456 H
Did not return on 12303 H and 12380 H.
I hope you guys try a blind scan regulary? (my receiver can't unfortunately).
El canal que comentas, esta como test, mientras no cambie el nombre, puede emitir lo que quiera.
The channel that you comment, is as a test, as long as you do not change the name, you can emit whatever you want.
12456 H.- TEST (BNT World) ==>left ==> Color bars /test card
Similar/Similary....
12303H TEST (BNT 1)
Anoche revise estos canales, viendo la programacion que tenian.
Miro la actividad del Astra19, Astra28, Hot Bird13 +Hispasat de forma rutinaria.
Despues de mirar Hispasat y pasar al Hot Bird, añadi este satelite por la pesca (gota a gota).
Por costumbre, lanzo una busqueda de los 3 TP's y luego miro con una busqueda ciega si hay nuevos tp's, mirar con el analizador de espectro tiene mas curro, pienso que los tecnicos se tomaran el fin de semana libre y no curran.
De momento sin mas cambios.
Last night I reviewed these channels, watching the programming that they had.
I watch the activity of Astra19, Astra28, Hot Bird13 +Hispasat routinely.
After looking at Hispasat and going to the Hot Bird, I added this satellite for fishing (drop by drop).
By habit, I launch a search of the 3 TPs and then I look with a blind search if there are new tp's, look with the spectrum analyzer has more curro, I think the technicians will take the weekend off and do not work.
At the moment without further changes.
El canal TEST "
continúa emitiendo", veremos que pasa dentro de unos dias/The TEST channel "
continues to broadcast", we will see what happens in a few days.
