C Band on 34.5w ..... KBC-KTN-NTV channels .. on or off?
guest poster
registered
Any C banders confirm if TP 3895 L 8594 (KBC KTN NTV) on Intelsat 903 34.5w ..NE Zone is still on or not...
Lyngsat & Flysat list it but Kingofsats doesn't and cant find it at KBC's site.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Hello pedro2000uk,
signal is here with mesh 12ft very weak with only <2dB S/N (Openbox X-810). To get this package - it´s very hard - you need >3,5dB S/N.
Best Regards
Edgar.
guest poster
registered
Thanks dx... I take it from that KBC etc.. are still on...
the footprints are a bit... vague
Do you think I'd get a better chance with 5w Panatlantic beam on 3656r 2893- that carries KTN
dx qwer
Rastatt/Germany
Hello pedro2000uk,
KTN on 3656 R 2894 3/4 (Atlantic Bird 3 @5,0°W) has much more stronger signal. With mesh 12ft now 7,8dB S/N -> you get this with >2dB S/N.
With 1,80m you get KTN on 3656 R (5,0°W) very good. It´s also possible with 1,50m, if you use an Waveguide Polarizer (see australian homepage from av.comm). I use this Waveguide Polarizer too!
If you have 1,20m dish it is not easy to get it. I would say that it´s not possible. But you can try it.
The signal for Kenyan mux on 3895 L (@Intelsat 903 @34,5°W) will need >4,50m dish...
Best Regards
Edgar.
guest poster
registered
Thanks for that infomation dx...
..the waveguide polarizer looks very interesting over a dielectric plate.... that's quite some gain...
issedin
i have 75cm dish from triax with duo lnb dreambox 600pvr s
nykoping sweden
hej guys am new to the site and hope u guys r from kenya. i am in sweden is it possiple to receive kbc channel one on Intelsat 802 at 32.9°E. pliz reply
issedin
nykoping sweden
my dish size is a90cm triax. and my receiver is from humax. thanks
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
i get KTN thru atlanticbird 5º with no issues using OP1.50 ,i´m located in spain (south-east)
guest poster
registered
check the very informative posts above from dx qwer... by that you need a much bigger dish just for the easiest ....5w c band... in Sweden... at a guess.. 2.4m+
34.5w would need a massive dish...
and 32.9e is out of the question in northern Europe ... it's a spot beam, too far away and too focused.
_http://www.lyngsat-maps.com/maps/intel802_spot1.html
issedin
nykoping sweden
thanks guys .it seems i have to move southen europe to get ktn..kkkkkkk. just joking....
in case i get the 2m+ dish and c-band lnb will the ku-band recever do it or i need a c-band receiver? if you guys have site where i can check , that will help too.
issedin
nykoping sweden
and about the direction? at the moment i receive hotbird and astra1 on my 90 dish with 6degrees monoblock lnb....is 5degrees west also on this direction?
guest poster
registered
most receivers have c band settings for the lnb...
yes the direction is west... 18 degrees west of the 13e and up a bit and the skew is over a bit for the ku band on 5w (French etc.)... the c band is circular
you can get a lot of African tv free on various sats in ku band if you motorise that 90... (not Kenya yet)
issedin
nykoping sweden
hej pedro.....
i found out that ntv kenya is available on eutelsat seasat at 36degres east and its a ku-band.....is that receverble on my 90 if its motorised? ...........thanx
dx qwer
Rastatt/Germany
Hello issedin,
no, it´s not possible for you to get KTN on (encrypted) MultiChoice Africa package on Eutelsat Sesat @36.0°E on 11142 H 30000 3/4.
This Ku-Band Beam is for South Africa and not for Europe. Pease check it @LyngSat!
Best Regards
Edgar.
guest poster
registered
NTV Uganda (kenya) 11647v 5000 on seasat 36e is showing as DVD S2 ...the S2 means that most satellite receivers won't receive it - HD receivers should.... but I'm not sure what non HD receivers are DVD S2 compliant.
here is the footprint
_http://www.lyngsat-maps.com/maps/sesat_fixed.html
the dish sizes are on the right so 90 in southern to mid Sweden is certainly OK if the map is OK.. only north is on the limit ... you could even try it with a 3rd lnb at the side of the 19e side if you are in the south.
What is on NTV for Kenya programming?
dx qwer
Rastatt/Germany
Hello,
sorry for my post! I read KTN Kenya and not NTV Uganda (Kenya).
Best Regards
Edgar.
issedin
nykoping sweden
they have comedies.. drama series reality shows....etc that is the home page _www.ntvuganda.co.ug
issedin
nykoping sweden
they have comedies.. drama series reality shows....etc one more thing guys.
is it possible to receive the uk channels on astra2 28degres east. with my dish if i motorise it..thax............residence.....southern sweden
issedin
nykoping sweden
_http://www.lyngsat.com/packages/mcafrica36.html ..............pedro is receiving that by any chance possible............
