Change from Sky Q to Freesat Help required
All installed and up and running, it took me about an hour to to complete the LNB most of that time was spent setting up the ladders and sorting out the cables. I only went up the ladders twice, once to remove the old LNB and run the new cable via the back up the dish, the second time to connect up the new LNB and fix it to the dish arm.
I still have to clip the cable to the walls but I tested the feed on the TV and everything works. :Y
Result.:)
