Thanks, yes I have emailed them this morning for a quote.
Thanks for your enquiry which has been passed to me.
Yes, we can offer the PPA actuator however this particular one is special in some way that is not obvious to me.
I will therefore need to ask Thomson in Sweden, who in turn will have to approach Thomson in the US to get price and availability.
This may very well take a couple of days or more.
I’ll get back to you as soon as I hear from them.
Best regards,
HMMM........£778.13
Probably better to buy a £50 one, replace it every 2 years for the next 30 years
Agree MB. We did a group buy some time back from Ricks Satellite in the USA. He managed to get Venture to ship direct from the factory saving the postage to him, so we cut one lot of postage out. Might be worth an enquiry to Rick?The Venture actuators are a lot cheaper than that.
For some reason 18" ones seem hard to come by and more expensive. I just don't have the clearance between the bracket and the floor for anything longer without losing some east positions.
It's the physical distance between the floor and the dish is the problem. It is fitted upside down and the pole was cut accordingly so I can't raise it any higher for more ground clearance.Could you change the lever/pivot point at either end of the travel ?
Not without digging 4ft down and excavating the concrete and fitting a new pole. It's not long enough to fit it the right was up.
Photobucket have disabled my links, I'll post a pic of what I mean when I get home from work. I appreciate any ideas really.
drats,
Look out for a second hand Jaeger 1224 H to H motor. It will give you a full East/West arc and requires no clearance at the back like an actuator does. A Jaeger 1224 can easily cope with a small dish such as a Gibertini 1.5m. Plus, a Jaeger 1224 will last a lot longer than one of the cheaper actuators, I have a Jaeger 1224 that has been operational for around 20 years and it still works OK.
If you cannot locate a second hand Jaeger 1224 motor, the alternative option would be a Moteck H180 motor. They are available new and will provide a full East/West arc without needing the rear clearance of an actuator.
Rgds
...and £200 for the actuator.
I've offered drats a brand new one, he thinks it wont cope with his 1.5. I didn't want to be pushy for a sale so left it at that.
