Chaparral monterey 140 problem !!
tuintje
Chaparral 20/40/115 and 140
Amsterdam
Who can help me with my 140 wich has several problems ??
The problems are:
Restarting is big problem, several times reconnect de AC-plug
The receiver gives a flash on the screen that says (require ac power reconnection to init)
No analoge audio
Change video and audio freq does not run (only by each touch 100khz up of down)
Already done:
I have several times reset the receiver (by AC-connector and also a new init with Volume up/down and power button)
New backup-battery placed
The Power supply gives the correct voltage on each connection.
Front panel looks fine ?
Has somebody an Eprom file for the 140 ??
Who can help me with my problem.
We use these transceivers for our hobby see: www.ljy.nl
Thanks very much
Cees <> PA3FCE
tuintje
Amsterdam
Unless you have something very special, the Monterey design is not a transceiver, though it did/does provide an RF output to a television .
Thanks very much for this information !!
PROBLEM:
Hardware Error keeps displaying on the receiver graphics.
SOLUTION:
The hardware error message can be caused from C31 being out of tolerance. This is a 0.1 uF cap. and should be replaced. It is possible that the cap may have been mis-stuffed or is missing. Using a scope check Pin 6 on U66. This pin should have a negative 0.5 mil/sec. pulse.
This item can be the problem !!
I have something to do !!
Best regards <> Cees
tuintje
Amsterdam
Chappie 140 Is working !!
Problem was C30 in the power supply, the ESR off the Cap was incorrect !!
By replacing the Cap everthing is Ok.
I am only looking for the Hex-file for the Eprom for the 140 (software revision (2-4-97) is: PT# 16-6619-1D ) can somebody help me with this file ??
Thanks to Channel Hopper for the support !!
I doubt very much you will find the software required, unless you sign up to a dedicated forum (by forum I mean something akin to the old newsgroups). On this site, members simply throw complete units in the skip.
Or you could look for a second hand model on the usual auction sites, copy the eeprom then sell on.
