I am collecting a mini dish with a suitable LNB for freesat on Monday, I think he said it has 4 outputs. Got myself a GT Media V8 Finder 2 to assist me with installation. Going to try and get 19.2e and view on my LG TV for the time being.I havnt used the S5x so cant comment.
Any news or decisions on the dish ?
The channel list would be great, yes pleaseGreat choice i find 19.2 more entertaining thesedays! Ok i can send you the channel lists/database file for that meter. As nothing will be preset. Let me know if you need it. So its just point and select a channel then watch for video whilst aligning.
Is it easy to add it?Thank you, appreciate it.Yes will upload shortly - nothing to it just plug in the usb flash drive and choose import
Buy a cheap satellite meter, which you can pick up for less than £10, or from stores, like B&Q, for around £13.Thank you, appreciate it.
My dish can be reached on a stepladder which makes things easier. The only thing I am unsure about is the elevation for 19.2, do you have any tips or guides for this? Just looked on DishPointer and it says this:
Satellite Data
Name: 19.2E ASTRA 1KR | ASTRA 1L | ASTRA 1M | ASTRA 1N
Distance: 38654km
Dish Setup Data
Elevation: 29.5°
Azimuth (true): 152.3°
Azimuth (magn.): 152.0°
LNB Skew [?]: -10.1°
Do the mini dishes have elevation markings? Sorry if that is a daft question!![]()
Thank you for this. I shall have a play when I get the dishV8 Finder V2 DB image - FTA Channel lists for -
4.8e
13e
19e
39e
Menu > Tools > USB Upgrade > UserDB > Start
Thanks for the files. I have unzipped archive and there are 2 files: GTMedia_V8FINDER2_V4.2.9.465, GTMedia_V8FINDER2_DB_SystemData, Is GTMedia_V8FINDER2_V4.2.9.465 a firmware update? I haven't even switched the thing on yet as it only arrived yesterday, just wanted to double check before I do anything!V8 Finder V2 DB image - FTA Channel lists for -
4.8e
13e
19e
39e
Thanks. I have updated the firmware to the latest from freesat.cn and flashed your UserDB file. Nice little unit, looking forward to having a play when I get my dishYou can maybe try just GTMedia_V8FINDER2_DB_SystemData.bin
I thought i would upload both just incase. Both files was created of the export of my meter config.
You dont have to flash the full firmware just press left again then it will give you the option to just flash the UserDB.
Can you explain how I use the device to align the dish please? I have gone to the Channel menu and Astra 1KR/1L/1M/ is displayed, from there I see channels 0001 - 0381. In Installion I see E19 20 and when I select it I get LNB Freq settings and other stuff.Cool do the imported channels appear now?
Yes the meter has the same OSD menu system as the GTMedia 7sx![]()
It sounds like you are on the satellite list menu. Use this to store new satellites. Such as 5w for example.
It's always better to use a pre-stored channel for dish alignment- so there's no confusion. You need to select a channel, such as MTV / ZDF etc.. on19.2.
Exit out of all menus.
Press OK> Press Blue> Astra 1kr> Select MTV, RTL/ZDF or whichever, then wait for the video. It might be worth pressing the right key to turn up the volume so you can hear the audio. Then press OK to get the SNR meter percentage bar up to fine tune.
Point the sat dish in the same way as all the other sky dishes, but lift a little higher the elevation, then move left and right. It's really easy!!!!
