Cryptoworks for Aston 1.03
henno
Motorised also one fixed with 19/13d arm and one fixed on28d E, os windows 2000
Ireland
Hi All
Does anybody know where I can download Cryptoworks cam file to flash Aston v1.03??? :cool:
Burnham Beech
Lefdata.
v1.12 and v1.14 work, v1.15 will destroy your cam.
But it's a waste of time, there is nothing you can do with the v1.12 or v1.14 versions.
henno
Ireland
:-doh! But what about Aston V1.03 can this be flashed to Cryptoworks??
Burnham Beech
Yes - Aston 103 will go to Cryptoworks v1.12 and v1.14
But these don't do anything with any known card, as I said first time.
henno
Ireland
Can Aston v1.03 be flashed to Nagravision??
Burnham Beech
Yes, but there is nothing interesting you can do with it now.
About a year ago there were funcard files that could clear the old nagra1 channels with a converted aston103 cam. The providers kept increasing the speed of the encryption until eventually the funcard files stopped working.
Nearly everything now is in nagra2 and that is beyond the cability of the SCM nagra cam.
MARK2000
PC ONLY
LONDON
Hi I have just bought a second hand Aston CAM v1.03 and cannot get it to work in Sony crt TV. Not sure if TV not working it properly or whether I need to upgrade to NAGRAVISION. TV recognises existing card though I am unable to access set up option. Setanta card does not work with it
Consequently, I believe version of the card is the problem. Does anyone know how I can upgrade the CAM to Nagravision?
TUTV uses seca 2 so theres no point upgrading it to nagravision!
MARK2000
PC ONLY
LONDON
Setanta card has nagravision all over it and assumed I needed Nagravision CAM? Aston CAM is seca marked so are you saying my card should work with it? Or do I need an upgrade?
It maybe connection with TV that is the problem?
Well blow me down - Setanta swapped from Seca to Nagra according to wikipedia.
So you do need a nagra cam or one of the new ones that emulate it.
MARK2000
PC ONLY
LONDON
Yes I believe that to be the case but elsewhere I have been told Aston v1.05 works? Is there a way to upgrade my card or is hassle not worth it? I.E. Should I just buy a Nagra CAM?
If you can find a setanta cam buy one of those. It will be guaranteed to work. An Aston 1.05 is seca - Ive got one myself lying around somewhere from years ago.
You do realise Setanta via DTT is the expensive way of watching Sultana dont you? Only one channel when the same money gets you all of them via satellite.
MARK2000
PC ONLY
LONDON
Thanks but have TOPUP TV until HD more mainstream and will then update box and TV!
If there is a way to update ASTON CAM then appreciate advice. Alternatively, you might send me your spare v1.05 card for me to try?:)
