damaged dish
cyprus andy
im a newbie, and need some advice please.
i have a damaged 2.4 m sat dish for sky , it is damaged. can it be repaired succesfully or is it junk?
thanks
Depends on the material its made of and how bad the damage is
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
cyprus andy said:
I have a damaged 2.4 m sat dish for sky , it is damaged
Can you post a picture?
I would say that it would be near impossible to get it back to peak operational efficiency, but you could straighten it some degree with some panel beating tools.
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
The first one should beat out nicely.
The second one is bad, but as Rolf says, you may get it somewhere near.
If it were me, I'd make a 'former' or template from the opposite side of the dish (once you take out the ding), and flip it over to mirror it. Use that with a hammer and dolly and keep checking against it. The longer you invest, the better it'll get, but it'll never be as good as new.
Try not to stretch the metal. Test it with a magnet. If it's steel, a little heat will help with softening before beating, and in reducing stretch.
