If you want it you go and get it. No files will be posted herekafathah001 said:Plz upload the file
cfphoenix said:see ump2002.net for all images, tools, cams etc for the dbox2.
As you know, it does what a dreambox can do and comes in various flavours, Nokia, Phillips and Sagem.
I am using the phillips with 2xI (£80 on Eby) and sold my dreambox 5620S.
Cheers.
mca said:Quite like a 5620, but they are a bit expensive, can a DBOX2 really do all a 5620 can?? I've found a few on ebay but they seem to vary widely in price ...some mention "premiere" with the box (are these boxes only for use with premiere channels?)
Thanks in advance
mca said:some mention "premiere" with the box (are these boxes only for use with premiere channels?)
yes mate you will need to have a feed from either one of the cable suppliers depending on which area you are tw,ntl,ex c&wjimbo_may said:I am new in here, if i buy the D-BOX2 that says cable ( telewest, C&W...) does it mean that i need only cable to use it, can i use it for a normal digital reception the same as i have now....thnx
