DCC problems
SMUGGLER
sky+ dream box 500s
Bristol. UK
Hi all i am hoping some one can help me. i have set up DCC but in communications set up i can only get green lights on nameserver and gateway,on DCC it says network ok. i have read dreambox for dummies at least twice and still cant figuire what i,ve done wrong on communications setup i have IP192 168 0 1 57 NETMASK 253 255 255 0 NAMESERVER 192 168 0 1 GATEWAY 192 168 0 1 on DCC this computer 192 168 01 Dreambox 192 168 0 1. maybe im a bit thick or have i done something wrong. Ihope someone can help me out. THANKS PS ive got a DM500 and using gemini image
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
You cannot have the same IP addresses for different pieces of equipment on the same network
although difficult to be sure from your typing and absence of complete addresses and or missing fullstops.
your netmask appears to begin 253 instead of 255
the absence of fullstops makes it difficult to know what you have input
in communication setup you appear to be either specifying port 57 or have last IP as 157 not sure
Keep it simple
PC 192.168.0.1
dreambox 192.168.0.10
something else 192.168.0.20
If your network uses a modem router you may find that it hands out IP addresses dynamically above a certain number leaving about 30 or so of the lower ones available for devices that need fixed IPs such as printers and, oh yes, Dreamboxes. You'll have to look at the modem manual to find out I'm afraid.
