diablo cam help
shanboy
hi all
france
i was update diablo cam with cas 2 but in the end of download cas2 show "error updating file" and the cam show 218 but not work
Mickha
North West
If the Cam is showing that Stealth 218 is loaded try updating the configuration settings.
Go into the cam menu, Stealth 218 and configuration.
Ensure you have the following:
Emulators ON
Auto PMT ON
Emulators Priority 1 Emu 2 Cards
Once you have these set you should open TPS on Hotbird 13E, by tuning into France 4, waiting a couple of minutes and once it is opened switch to any other channel in that package.
For D+ you will have to manually update the keys.
Go into the Cam menu, Stealth 218, Keys, List Keys Edit, 004101 Digital +, and edit the correct key.
IDEEA Key 86 = Key 00
IDEEA Key 96 = Key 01
If you experience any problems please post back.
shanboy
hi all
france
thank you for explain;
but the cam show only 218 , but can't be open the menu of cam , and i try to uptading again with cas 2 ,in end of download cas2 show 'error updating file'
Mickha
North West
Try downloading, and installing, CIS 7.9C, from duolabs web site.
To get this to work you will have to alter your computers clock, set it to 2006 while using CIS 7.9C, then try formatting and installing Stealth 218 again.
There have been issues with the Cas 2, sometimes it take a few times before successful updates.
shanboy
hi all
france
thank you Mickha , i try with cas 3 it work good
diablo cam cant be upgrad with cas 2
