Diseqc Motor speed
teltras
Channel Master 1.2mts superjack 18´´
Famaval 135PM Aluminium offset superjack 18´´
Famaval 1.0mts with diseqc motor Digipower SG-2100A
Andrew/Channel Master 1.2m with Jaeger SMR1224
Receivers:
Gigablue Quad UHD
Gigablue Trio 4K
KIII pro
Dm800HD
Portugal
Where is the option to change motor speed fast/slow, I do remember to change it once but now I cannot find it.
thanks
Trust
Nijmegen Netherlands
Vertical is 13 v horizontal is 18 v
teltras
Receivers:
Gigablue Quad UHD
Gigablue Trio 4K
KIII pro
Dm800HD
Portugal
No, its not that but thanks.
I do remember its a setting somewhere on enigma to slow down the speed of the motor, to reduce noise and speed. I do remember it says "fast" and "slow" and we can select it, maybe it was only on openatv 6.2, I need to check it again, on the 6.4 I cannot find it.
On the openatv 6.4 "inside extra dish positioner options" is not there. only º/sec and turning step size º but I will not touch that.
Magmax
Croatia
freesattvforum.createmybb4.com
Nytrobox 6000 HD Combo 90 cm motorized dish vith a Engel Digi Trekker motor
Croatia
All i know os that there is Usals automatic and Manual left right.
