Archive4
Yep, works fine, karaoke version too, even put the lyrics up for youRainy night in Georgia?
One day I'll fly away!!!!
(does this link work? Never tried it before....)
The reason the like button was not there was because the forum software does not allow self gratification, also, even though you may change the post, the original is still in the e-mail alert , although no longer visible to others. ( Which is why the rest of you think I´ve gone mad ),
But you know what I mean!
28 mins ago, to be precise! (h5)Yrah, I noticed, that I was looking at my own post and removed this sentence about button not being there 5 minutes ago.
Nope. There are other reasons...( Which is why the rest of you think I´ve gone mad ),
There are 16 (14+2 spare) TBS6910 on multiswitch outputs and 8 (4+4 spare) TBS6909 cards on multiswitch's cascade (those cards have internal switches, so they need direct quattro input) for FTA channels.
Now, that's nothing special - they are intended to be stuck to their own satellites. So, you just plug them into cascade output of multiswitch and that's all.BTW,
Now that we have come this far.... I'm curious how you will connect and switch these TBS6909's for four satellites?
Well, I don't know much about these computer receiver-cards.
What puzzles me though, looking at the specs of the TBS6909, that it needs quatro input (as you wrote), and still supports diseqc 1.0 and 1.2.
Can you enlighten me how that diseqc support would be supposed to work, with quatro inputs?
Greetz,
A33
No, it's not available in 8 tuner mode, that's why I'm connecting those to cascade output of multiswitch. They won;t see other satellites, only one.Presumably you've checked to make sure that DiSeqc is available in all three modes?
They are used in different modes.
8 tuner mode (inputs should be VH/VL/HH/HL)
8 tuner mode Unicable (one connection from Unicable LNB on first port)
4 tuner mode (normal switchable inputs)
.... thanks to this rather excellent project I found a while back..
Might I suggest building one yourself ?
It will prove what signals are generated and where they reach ..
I find mine very useful indeed..
Diseqc Decoder project ..
Of course ..you then need an accurate diseqc hex table in order to interpret the results ..
..and sadly not all receiver manufacturers bother to follow Eutelsats protocols exactly ..
Many take shortcuts ...which is where a lot of the problems and confusion can arise.
(If anyone finds a concise dieqc byte analysis lookup chart - please post it here ...it would save keep digging into Eutels lengthy pdf)
