dish material types
Yes, but you can move the other dish more to the right, as it won't get in the way of the Sky dish.
wod
yorkshire
well finally got around to buying some kit and have bought
_http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=011&item=320043383511&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1
well i put in an offer and it was accepted
is it ok as i dont think i will need a 1m dish just yet as i'm after 13,16,19 east first to have a play about
R
Rd100
Good little bit of kit there now all the fun starts. What receiver are you going to use with it.
wod
yorkshire
well i have a technomate 1500 ci but just hoping the dish aint too small for digitalb , can this be recieved on the 1500 ? with it having high symbol rate ?
R
Rd100
is it just the 1500+ or the 1500 super you have, the dish will be fine for digitalb, Are you going to buy a digitalb card then,
wod
yorkshire
yes its the non super one i have as i bought it cheaper than the super and works fine, its quick at scanning channels
why have i got the rubbish one if its not the super model ?
yes was looking a buying the supersport digitalb card
R
Rd100
i use to have the 1500+ but now have the 1500 super,
I have digitalb but i do not have supersport
The only diffrents is the 1500+ will take about 15 hours to do a blind scan but the 1500 super can do it in about 7 min at the most,
wod
yorkshire
hmm so its crap then , not really fussed about blind scanning and all that but least its better than a sky dodgybox
R
Rd100
No it is not crap just it can not do a blind scan unless you want to wait over half of a day,
wod
yorkshire
well the dish arrived and came undamaged
the dish looks abit cheap though to say its a triax one but its massive to say its only 90cm
also got 25m of some white cable which looks like wf100 as it has a foam core but it has like silver braid , what type is this ?
