DM500s 22khz tone circuit board fix
It's an FDN358 MOSFET (as shown on the schematic posted above).
ambu
dm 800hd withh 7 sattelites hotbird arabsat nilesat eutelsat w3 chinasat 115e panmsat68.5e and am using windows xp
oman
pls can any one give me part nos of q72 q71 q70 can i put a cross wire to these 3 transistors and how or better to replace them thx
mark4fs
Newcastle
loads of stuff
tyne and wear uk
Can anyone tell me where I can buy these I had voltage from tuner but only had 20% and no agc and high ber8600 led for 22khz wasn't lighting up I tried a link from q72 to led and got it to light up but must have shorted it coz it then burnt out I know q71 is a bc817 there's some on fleabay seems like this problem is very common so if we can all bang heads together might save chucking these boxes in the bin I have smt soldering abilities and tools so want to try and fix this just like the guy who started thread so hopefully we can help others
BMOE
DM-500S
Sweden
Yes, sorry about that.
Here is the real link:
=http://lakebransh.blogspot.com/2011/03/dm500s-lnb-problem-fix.html
/Matias
Thanks on behalf of anyone experiencing the same problem. Just be sure the capacitors are good quality and high temp. rated (105C), or it'll be back to the soldering iron later.
BMOE
DM-500S
Sweden
Today I fixed another one by changing the capacitors and now it works just fine.
pacmyc
DM 7000S
Project Gemini 4.40
Nabilosat Darkstar II
Stockholm
Hello. I just received a brand new (but faulty) DM500S from DX.
I opened up the cover and saw that a small coil is broken, it's right next toL704.
Do you know the specs of this component? It shouldn't be difficult to find if I know the specs.
And also, Im, facing the problem that Gemini Project 4.7 doesnt find the tuner, could it be because of this coil?IMAG0124.jpg
