downloads
M
mintycoop
Hi where have all the downloads sites gone, i have been searching for over an hour, they have either been closed down, or have been turned into discusion boards, and do we pay for the other side,any ideas.
Try this site for some good links, that is if you haven't already.
http://lsuk1.proboards.com/index.cgi?pbuser=lsuk1
Rolf
M
mintycoop
hi i have been searching, and my hair is now thining as i have ripped it out, someone tell me please, ive got a razor blade pressed against my wrist, an ill use it, it will be your fault.
Are you sure the batteries in the razor are up to it ?
M
mintycoop
phewwwww!!!! that was close, i nearly did it, the shag pile was nearly stained then, thanks you guys, i thought you would not let me down.That is one reason why,i look at this site every day, and i bet a lot of people are visiting those links now, thanks again.
