DVB-S2X (TBS 6522)
satosk
Be independent and your TV screen will never be the same.
Slovakia - Heart of Europe
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
First DVB-S2X reception by Peon (Onacila) with TBS 6522.
Astra @ 19.2E, frequency 11552, SR 25502, FEC 11/20
View attachment 98641 View attachment 98642 View attachment 98643 View attachment 98644
Capabilities of this new TBS 6522 card can be found here: TBSDTV Community Forum • View topic - TBS 6522 tests
Receiving transmission on my LG TV satellite tuner. Its caption id "Dolby Labs" and is in UHD. Might be for Dolby Vision testing. Nothing shows for this signal on Dr.HD D15
anto@
italy
stored channel on my tv hi sense
A/S edit - pic put into thread
Please dont use image tags from picture hosting sites - they are flaky at the best of times. Upload the pics using the upload a file option lower right in the reply box.
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
it looks fine here too.
Best Regards
qwer.
MCelliotG
Thessaloniki, Greece
Looks good and I'm tempted, however I don't see ACM in the specs, does it receive the multistreams correctly?
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
A news article on IBC and DVB-S2X is on
wxw.thebroadcastbridge.com/content/entry/6648/dvp-to-showcase-ip-and-dvb-s2x-for-in-home-use-at-ibc-2016
( Change wxw to www to achieve live link)
CrazyCat
crazycat69.narod.ru
13E 4.8E 4W: Dish Variant CA-902 0.95m + 3xLNB Ku-Universal DreamSat DS8 + DiseqC 1.0
30W-95E: Dish Strong 0.95m + LNB Ku-Universal ALPS BSTE8-751B + Motor PowerTech DG240
OpenBox X-800
TT S-1401 PCI
Omicom S2 PCI
TBS 5980 USB2.0
Ukraine, Kharkov
What LG TV model ?
Most LG TV use Silabs tuner/demods since 2012/13 year. So 2016 models must have six generation silabs demods with DVB-S2X support (broadcast profile). Most used is Si2169 with DVB-T/T2/C/S/S2X support - Si2169 Digital TV Demodulator | Silicon Labs
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
What LG TV model ?
I am using the LG EF950v which is a 2015 model. Not sure what demodulator it uses.
anto@
italy
my hisense
lcd43 h43m3000 led ultra hd
Fine here with the TBS 6522 card just received. OK with DVBDream, although FEC has to be entered as Auto, as there's no provision for inputting this channel's 11/20 rate.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
New receiver claims to do dvb-2x:
OCTAGON SF4008 available January.
It is a Linux twin Satellitereceiver that take a hard disk and does terrestrial as well.
OCTAGON SF4008 UHD 4K 2160p Triple E2 Linux Receiver
HARDWARE:
- Processor BCM 7251S
- 12K DMIPS (12000)
- 2 x 1700MHz Dual Core (2x1,7GHz)
- NAND Flash 4GB eMMC
- RAM 1GB DDR4
- HVEC / H.265 video decoding
TUNER:
- DVB-S2 DUAL
- DVB-C / T2 DUAL
- As PNP version, up to 3 tuners maximum
FRONT:
- VFD dot-matrix display (white - white) 16 digits
- Power button touch
- CI & CI + slot
- CA smart card reader
- 1 x USB 2.0
REAR (rear):
- Power on / off
- Dolby S-PDIF
- 2 x Plug and Play Tuner slots
- LAN RJ45 Gigabit Support (1000Mbps)
- 2 x USB 2.0
- 1 x USB 3.0
- HDMI 2.0
INSIDE (inside):
- HDD 2.5 inch SATA
DIMENSIONS:
- 260 x 135 x 45mm
satosk
Along with a few other satellite projects that are currently in progress, we still keep testing all TBS cards as we go along.
One may say, it`s not a big deal to do such tests. Well, good and relevant tests take lots of time, patiente and effort. But as you can see, it pays off!
TBS 6522 - sensitivity tests.
If TBS 6983/6903 are great, TBS 6522 sets a new limit!
Those tests have been done several times, the player was completely closed down and open when a device was switched. DVB Dream was used for Prof 7301 because the latest version of Smart DVB causes Prof to crash. But on the end of the day it doesn`t change anything on the fact that there`s only one card that could fully and freeze free provide picture and sound on this station/transponder.
Pictures say it all.
NTN24 - TBS 6522.jpg NTN24 - TBS 6983.jpg NTN24 - TBS 6903.jpg NTN24 - TBS 5925.jpg NTN24 - Prof 7301.jpg
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
HARDWARE:
- 12K DMIPS (12000)
- RAM 1GB DDR4
TUNER:
- DVB-S2 DUAL
- DVB-C / T2 DUAL
FRONT:
- CI & CI + slot
- 1 x USB 2.0
REAR (rear):
- Power on / off
- Dolby S-PDIF
- 2 x USB 2.0
- 1 x USB 3.0
- HDMI 2.0
INSIDE (inside):
- HDD 2.5 inch SATA
DIMENSIONS:
- 260 x 135 x 45mm
More details@
mysatbox.tv: Octagon SF4008, the cheapest 4K STB
4Himdj
1.2 Laminas Dish
Rome
View attachment 100182 View attachment 100183 View attachment 100184 View attachment 100185 View attachment 100186
hello this test is what I prefer in order to compare sensitivity.
I've 2 questions:
1) which tbs usb tuner is more sensitive 5925 or 5980?
2) do you know if tbs will launch a new usb "multistream ready" card?
thank you very much
best regards
I've 2 questions:
1.The most sensitive tuner from tbs is 6983(HW v.13),
2.Has not yet been released,but I think USB 5927 is the best and surpasses the performance of the existing USB regardless of brand.Approaching 6983...
blademedia
Sky
You wouldn't be disappointed with the sensitivity of the 5925, it matches my most sensitive receivers, Kuban tv @ 60E is a hard lock for me on small dish the 5925 has no problems with it
archive10
Can I ask you gentlemen from where you purchase these cards?
I've only found tbs-technology.de as proper reseller in Europe.
I bought my 5922 from there. No complaints from me on that.
But surely there must be other resellers locally, in contrast to buying direct from China?
4Himdj
1.2 Laminas Dish
Rome
I need to sell mine tbs 6983...:)
