Manikm909
Small'ish Dish Man
- Sep 10, 2020
- Age
- 47
- Channel Master 1.8M on Edision MIO 4K & GTMEDIA Combo, and CM1.2M on Octagon SF8008
- Kent, UK
...... "lobster" ........Just get it above the garage roofline, and maybe further "back" towards where it first was -then 52E should be your "oyster".
"oyster", "lobster" - I'm not particularly partial to either, but "whatever takes your fancy" as far as crustaceans are concerned...... "lobster" ........
... and do away with DISEQ motors forever....
you can tell its Friday!My Channel Masters have never needed to be re-aligned once after storms/wind, Az/El or polar mount. The main dish is only 2.5M above the ground but we get very strong winds here.
If you fine tune the polar mount at ground level on a plumb pole, and your pole in the final position is plumb, once the dish is up all you need to do is get the azimuth correct. I found it's much easier to rotate the pole than to rotate the polar mount on the pole, so you need not be up a ladder to fine tune it.
i think i will get my lopper out, WAHAY!!!!
Any actuator will be fine as long as it's mounted on the left side when looking from the rear, which is preferable for eastern satellites.also - where its sited currenly is there enough room on the back do you think to accomodate an actuator....12 or otherwise
"Same difference"crabs !
If the "house is in the way" is the "problem" then there'll be no difference between using the DiSEqC motor and an actuator approach - until you put the dish back where it was, i.e. above the eaves of the house roofgood idea mate! will try that.
i hope someone on here might want my Laminas if i can get this CM going....
"No such problem/solution" required! - just cut that "local" bush/tree "down a bit" and move the existing pole and dish as far as possible to the "right" on the garage wall as you can. That way you should be able to get 52E (and maybe further East?) without changing the means of rotating the dish.id rather it be where ive moved it too i.e the garage, id rather it be away from the house, and on the garage (and so would the mrs).
if i have to raise it above the garage roof, then so be it, id rather that then trust ladder resting against gutter and also the extension roof isnt flat (old old location)
so do i want a 12" or 18" actuator for 53e 45w ?
maybe i could start by cutting this down....its my "bush"
there is also a tree in the background but i doubt thats the issue
I REALLY can't understand your new "obsession" with the V-box + actuator approach because if you can't get 52E with a DiSEqC motor then you WILL NOT get that with a V-Box and an actuator because the HOUSE IS STILL IN THE SIGNAL PATH !thanks, that did cross my mind, but then i think it will be too close to the neighbours shed - also, its very bushy down that side of garden border, so i think other sats will suffer from 5e up to 53e
i think raising it where it is, is the best option for me. not much work, just hassle. i will need to source vbox and actuator and get the CM commisoned
