OldBen
Mad Scientist
- Jul 29, 2005
- Age
- 47
- Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch. VU+ Duo. Emitor Satlook Lite meter.(Retired: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB
- UK
So... its a 9pin serial to a 3.5mm stereo jack, but I can't find the cable, or rather I can find 3 cables of this type but some are for disk arrays and I am not sure which is which!
Can anyone tell me assuming shield is ground which out of pin/ring is TX or RX? If you have a cable multimeter and 10 seconds of your time would be appreciated Pin 2 on serial is RX, Pin 3 is TX and Pin 5 if ground.
