EPG with Dreambox600 on BSKYB
Dreambox DM600 Official, DM500S Clone, Linux MythTV, Nova-T USB2 Stick, Nova-S-USB2 Tuner, S*y Subs, TRex -CAM, Satelco EasyWatch PCI DVB-S + CI Interface
West Midlands, England
tomthebomb1968 said:
Weekepg 3.1 works well on a 600
I don't believe there's yet been a release for the Pli-Jade images as yet. When you try and install/use it, you just get symbol errors.
Other images do have it though.
erukus
a sky mini dish + a Dreambox 600S with Gemini- 430 and CCcam 2.0.8
Cornwall UK
Is there any update on this issue with regard to an easier solution such as a plugin or an addon from gemini server?
erukus
Cornwall UK
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
The best solution is to install OpenPli as it has a downloadable EPG that works great (se other thread). If you really dont want to install Pli, then you can download from _http://www.rytec.be and EPG plugin and configure it yourself, but I recommend installing Pli, as you get other benefits as well.
shumifan50
Europe
