Eutelsat Hot Bird 13°E
I have not tracked which transponders have been moved to the newly operational Hotbird. Therefore I am not sure to what extent the following transponders were active before the switch, all of which are also with S2X extension.
I did a full band scan on the H/V; only the upper band might still be active muxes that can't be locked due to the problematic, weak signal. At one point, I managed to lock 12728 H,27500,3/4, and see what the content is
How is the signal in your area, especially between 12600-12750 HV?
11194 V,22856,32/45,8PSK-Data,
11604 H,31428,8/9,16APSK-Data,
12743 V,22856,32/45,16APSK,0.05-Data
wow it use high band data
any signal dvb 2x
eutelsat test live signal with data stream on 1.5e before move to 13e
maybe check more tp will be use it
EnoSat
enosat.euweb.cz
Slovakia
It looks like the card from 12700 is handling some harmonics
12707 V = 11158 V (hypothetically)
12728 H = 11179 H
12743 V = 11194 V
check tp 12731h
more tp will be come on 13f when arrive to 13e
like ebu it was tp for sky italy
EnoSat
enosat.euweb.cz
Slovakia
PoC
tp.66 - 12072.72 V
NID-318
TID-6800
BPK TV - 224.30.6.10
MotoGP - 224.30.6.1
satelliclub
Eutelsat 5 West B + Eutelsat 9B
Tunisia
For some hours they have turned off the test carriers on the frequencies 11035 V, 12585 H and 12665 H.
For now the telemetries are still in linear polarity (On-Station).
Awaiting to starting to move to 13°E ....
@EnoSat 12072 resev tp of sky it tery testing signal
EnoSat
enosat.euweb.cz
Slovakia
This transponder is not for skyIT
C++:
Guess table from table id...
DSM-CC DATAGRAM-decoding....
Table_ID: 62 (0x3e)  [= DSM-CC - private data section  // DVB datagram]
section_syntax_indicator: 1 (0x01)
private_indicator: 0 (0x00)
reserved_1: 3 (0x03)
Section_length: 377 (0x0179)
MACaddrbyte/DevicdID 6: 7 (0x07)
MACaddrbyte/DeviceID 5: 100 (0x64)
reserved_2: 3 (0x03)
payload_scrambling_control: 0 (0x00)  [= unscrambled]
address_scrambling_control: 0 (0x00)  [= unscrambled]
LLC_SNAP_flag: 0 (0x00)
current_next_indicator: 1 (0x01)  [= valid now]
Section_number: 0 (0x00)
Last_Section_number: 0 (0x00)
MACaddrbyte/DeviceID 4: 100 (0x64)
MACaddrbyte/DeviceID 3: 94 (0x5e)
MACaddrbyte/DeviceID 2: 0 (0x00)
MACaddrbyte/DeviceID 1: 1 (0x01) => MAC-Address/DeviceID: 01:00:5e:64:64:07
IP_datagram_bytes:
    Version: 4 (0x04)
    IP header length: 5 (0x05)
    Type of service: 0 (0x00)
    Total length: 364 (0x016c)
    Identification: 7823 (0x1e8f)
    Reserved: 0 (0x00)
    DF: 1 (0x01)
    MF: 0 (0x00)
    Fragment offset: 0 (0x0000)
    Time to live: 128 (0x80)
    Protocol: 17 (0x11)  [= UDP]
    Header checksum: 28078 (0x6dae)
    Source address: 0a0a1ece [= 10.10.30.206]
    Destination address: e0646407 [= 224.100.100.7]
    UDP_datagram:
        Source port: 49584 (0xc1b0)
        Destination port: 5000 (0x1388)
        Length: 344 (0x0158)
        Checksum: 11335 (0x2c47)
        Data
              0000:  80 a1 dd a0 d9 d9 52 97  e0 64 64 07 01 01 6e d0   ......R..dd...n.
              0010:  6c 69 76 65 5f 63 61 74  61 6c 6f 67 2e 63 73 76   live_catalog.csv
              0020:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0030:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0040:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0050:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0060:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0070:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0080:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0090:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              00a0:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              00b0:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              00c0:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              00d0:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              00e0:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              00f0:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0100:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0110:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0120:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00   ................
              0130:  00 00 00 00 00 00 00 00  00 00 00 00 00 00 01 c0   ................
              0140:  00 00 00 01 00 00 00 00  05 00 00 00 64 af cd c4   ............d...
CRC: 3052188308 (0xb5ecb294)
PID:  1012 (0x03f4)
Section_length: 509 (0x01fd)
IP_datagram_bytes:
    Version: 4 (0x04)
    Total length: 496 (0x01f0)
    Identification: 45197 (0xb08d)
    Reserved: 0 (0x00)
    DF: 1 (0x01)
    MF: 0 (0x00)
    Header checksum: 56107 (0xdb2b)
    UDP_datagram:
        Length: 476 (0x01dc)
        Checksum: 28714 (0x702a)
        Data
              0000:  80 21 dd 85 d9 7b a9 8f  e0 64 64 07 01 03 6e c2   .!...{...dd...n.
              0010:  00 00 00 00 75 6e 6b 6e  6f 77 6e 2f 62 70 6b 2d   ....unknown/bpk-
              0020:  74 76 2f 6f 72 70 30 31  2d 74 65 6e 30 31 32 2d   tv/orp01-ten012-
              0030:  63 68 30 31 30 2f 68 6c  73 2d 73 62 2f 69 6e 64   ch010/hls-sb/ind
              0040:  65 78 2e 6d 33 75 38 3b  6d 69 3d 32 32 34 2e 33   ex.m3u8;mi=224.3
              0050:  30 2e 36 2e 31 30 26 6d  70 3d 36 30 30 30 26 6d   0.6.10&mp=6000&m
              0060:  69 69 3d 30 26 6d 70 69  3d 31 26 73 74 3d 68 6c   ii=0&mpi=1&st=hl
              0070:  73 26 73 72 69 3d 6f 72  70 30 31 2d 74 65 6e 30   s&sri=orp01-ten0
              0080:  31 32 2d 63 68 30 31 30  5f 68 6c 73 5f 6e 69 70   12-ch010_hls_nip
              0090:  26 6d 69 61 3d 32 32 34  2e 33 30 2e 36 2e 31 30   &mia=224.30.6.10
              00a0:  26 6d 70 61 3d 36 30 32  30 26 6d 69 69 61 3d 30   &mpa=6020&miia=0
              00b0:  26 6d 70 69 61 3d 31 26  6d 69 64 3d 32 32 34 2e   &mpia=1&mid=224.
              00c0:  33 30 2e 36 2e 31 30 26  6d 70 64 3d 36 30 34 30   30.6.10&mpd=6040
              00d0:  26 6d 69 69 64 3d 30 26  6d 70 69 64 3d 31 26 70   &miid=0&mpid=1&p
              00e0:  6c 61 76 3d 31 26 72 74  6f 3d 36 30 0a 75 6e 6b   lav=1&rto=60.unk
              00f0:  6e 6f 77 6e 2f 31 31 39  31 34 2f 46 48 44 2f 6d   nown/11914/FHD/m
              0100:  6f 74 6f 67 70 2f 6d 61  73 74 65 72 2e 6d 33 75   otogp/master.m3u
              0110:  38 3b 6d 69 3d 32 32 34  2e 33 30 2e 36 2e 31 26   8;mi=224.30.6.1&
              0120:  6d 70 3d 36 30 30 30 26  6d 69 69 3d 30 26 6d 70   mp=6000&mii=0&mp
              0130:  69 3d 31 26 73 74 3d 68  6c 73 26 73 72 69 3d 6f   i=1&st=hls&sri=o
              0140:  72 70 30 31 2d 74 65 6e  30 31 32 2d 63 68 30 30   rp01-ten012-ch00
              0150:  31 2d 68 6c 73 5f 6e 69  70 26 6d 69 61 3d 32 32   1-hls_nip&mia=22
              0160:  34 2e 33 30 2e 36 2e 31  26 6d 70 61 3d 36 30 32   4.30.6.1&mpa=602
              0170:  30 26 6d 69 69 61 3d 30  26 6d 70 69 61 3d 31 26   0&miia=0&mpia=1&
              0180:  6d 69 64 3d 32 32 34 2e  33 30 2e 36 2e 31 26 6d   mid=224.30.6.1&m
              0190:  70 64 3d 36 30 34 30 26  6d 69 69 64 3d 30 26 6d   pd=6040&miid=0&m
              01a0:  70 69 64 3d 31 26 73 73  75 3d 75 73 26 73 6b 61   pid=1&ssu=us&ska
              01b0:  3d 32 30 26 70 6c 61 76  3d 31 2c 32 2c 33 2c 34   =20&plav=1,2,3,4
              01c0:  2c 35 2c 36 2c 37 26 70  6c 61 61 3d 31 2c 32 2c   ,5,6,7&plaa=1,2,
              01d0:  33 2c 34 0a                                        3,4.
CRC: 1292221083 (0x4d05ba9b)
12072 V,29900,5/6-10 PoC, prov. Eutelsat
Pid 1012: 224.30.6.10
it data service on test
I have now discovered that the IP stream on 12072 V is a Eutelsat promo and how to view this stream under Linux.
It should be taken into account if there will be more streams activated. Notice to those interested.
that suprise eutelsat upload video stream on 1.4e before move final location
I need to clarify: what I have received, including this mux-12072 E, is from 13.0E, not another (tested) position. And it's no coincidence that I posted the Hotbird spectrum above.
With apologies, if I have the wrong topic; move it to the right place.
EnoSat
enosat.euweb.cz
Slovakia
I Demo
11470.76 V
NID-318
TID-1400
France 24 - 224.30.3.11:6000
Eutelsat Africa 7E - 224.30.3.12:6000
Eutelsat America 65W - 224.30.3.13:6000
Arianespace - 224.30.3.14:6000
Eutelsat Asia 172E - 224.30.3.15:6000
Eutelsat America 117W - 224.30.3.16:6000
Meridian - 224.30.3.19:6000
capture_001_13082023_203156.png1_0_1_0_0_0_0_0_0_0_20230813204003.jpg1_0_1_0_0_0_0_0_0_0_20230813203210.jpg
NIP Demo
10949.34 V
NID-318
TID-12200
224.31.5.1.50002 - A1/HD
224.31.5.1.50003 - A1/SD
224.31.5.1.50004 - A1/UHD
224.31.5.1.50005 - A1/audio
224.31.5.1.50006 - B1/HD
224.31.5.1.50007 - B1/SD
224.31.5.1.50008 - B1/audio
SimonE
Gloucestershire, UK
DVB-IP None of my satellite boxes will produce anything sensible from 12072V 29900 2/3 QPSK mode=CCM on 13E BUT my HD Ranger found 4 TV channels and 6 Radio channels.
TV
La7d HD SID=73
La7 HD SID=79
ZONA DAZN 1 SID=801
ZONA DAZN 2 SID=802
RADIO
Radio 101 SID=101
RMC SID=102
Virgin Radio SID=104
Radio 105 SID=105
Radio SUBASIO SID=106
Radiolina SID=110
The TV stations are all scrambled but all the radios work!.
EnoSat
enosat.euweb.cz
Slovakia
That's 11919 V
12073V is
11919-10600=1319 MHz
12073-10750=1323 MHz
Didn't you have LOF selected at 10750 MHz ?
it use transponder mediaset 11919 and 12072
EnoSat
enosat.euweb.cz
Slovakia
Mediaset does not use the 12072V transponder.
The Proof of Concept project is intended for another Eutelsat partners.
how see sid all channel 11919v
