I have never considered adding reflector area in a few places as a solution to
increase signal quality. To get a good match to the feedhorn properties is a
lottery with small chances to win. There are many ways to ruin things and
only one way to get good results.
I have planned to do tests in a completely different area, reducing the influence
of the metal structures supporting the LNB. The three metal rods to the focal
point will cause diffraction and some signal losses. When the weather permits
I will compare carbon fibre tubes to the metals tubes used now. Carbon fibre
is a fairly good absorbant of microwaves and the influence of the coax to the
LNB can be reduced running it inside one of the carbon fibre tubes. First I must get
signal strength measurements working, the changes will be small but a quick
test showed a change of 0,2-0,3 dB when adding a fourth rod to the dish.
The daily variation is just as big so it needs some work to separate that from
the influence of the three rods.
Adding absorbant to the metal LNB holder is another test that my be done.
(I've got a well-filled scrapbox of absorbants. Hard to find otherwise.)
