antrabe
- Feb 1, 2017
- dreambox7080 dm900 viark droi
- spain
It works super the rotor can move the dish without issue i think is still can handle a heavier dish.
Im trying to adjust the motor im gettings very good results with this installation better than with televes 1.1m. On Astra ARD Hd now i get 18db before 14db.
im expreience the problem about the adjustment if i receive strong astra i cant get hispasat and i think all the parameter are ok.
My location is 37.4N Longitud 4.8W then my sat to adjust should be 5W if i do the calculation the rotor should be placed at:
-5- (-4.8)=-0.2 but if put the rotor on 0.2W then the motor on 37.4 and the dish on 24 according to the map attached i dont know what happen that i cant get East and west at the same time.
Any advice? the pole is correctly vertical.
