Help Required Fringe reception in Munich, Germany with 150cm dish and Technomate TM-Twin 4K receiver
kingkvndrick
150cm Gibertini satellite dish w/ Technomate TM-Twin 4K receiver
Munich, Germany
Hello,
I live in the north of Munich, Germany and I have a 150cm Gibertini satellite dish connected to my new Technomate TM-Twin 4K. The LNB I have is the Opticum Quad LNB - LQP-04H.
I am not able to pick up a clear signal on standard BBC channels on my Technomate receiver, I can get a clear picture of BBC SD and HD channels during the day on my LG HR550S receiver.
During the evening however (after 6 ish), I lose the signal and I don't get any channels on either of the receivers. This happens every evening.
I laid new CAT 6 satellite cables yet the issue still remains. The dish is adjusted in the best way possible.
Thanks.
Hello welcome to the forum. You need a bigger dish - the symptoms you are seeing are absolutely typical of ultra fringe reception with ultra marginal reception. You probably need to go up at least 2 dish sizes, possibly 3 to get decent reception.
mickwig
90cm Astra1 dish;
Hi, it will get better as the year goes by. Around Christmas the reception is at its peak and the slowly degenerating towards summer solstice. I live about 200 km north of you and tried everything. At 240 cm ist works okay except really bad weather in summer. I suppose you could try a 180 cm of good quality. Best time to try is now, because the reception is at its worst now.
4wd
Getting the picture
5 W, 9-13-19-28 E
Looks like you are experiencing the same "near-null-lobe" reception as I have in Bergen-Norway, decent daytime and fading away into a massive abyss in the evenings.
Daytime I could sometimes get the strongest UK transponders with a 60cm, but needed a CM 180 to get all UK's stable 24\24.
Regarding adjusting, every mm counts + test lnb's, try different receivers, may gain a few db's (you've surely already tried things), but large dish is the real solution.
itchybag
1.1 stab motor with VU+ SOLO 4k, dm800, prof 7500
earth
hows your 27.5w signal, it should boom in on that bird.
