O
Old Fred
I haven't read *any* comparison reports on the TU-DSB40 - so you might be the first to write one!tsilva said:Any succesful lnb pointers too for using with the pace? I'm wondering whether it's worth swapping receivers - sounds like it might be.
As regards LNBs, again I can only report what I've read. The Manhattan MTI 0.6dB is said to be very good for dishes up to 1.5m. Beyond that size, the Invacom 0.3dB twin-output* version is said to be the best (in Cyprus on a 2.7m dish for example). However, in all cases, you get a better result if your dish uses the separate feedhorn that came with it so that you can bolt on an LNB with a C120 flange.
* The single-output Invacom reportedly gives much poorer results.
Fred
