Help (farged it again)
Burnt Chips
Overclocker Supreme & General Mad B*st*rd
sunny manchester (i wish )
Seting up my C master 120 (offset)and somthings gone wrong: When setting east/west limits they are reversed, ie reed counter counts down after East set 1000: and really farged when get too Zero with plenty of west travel to go, Now i`m using same actuator 24 jaeger,
as i used on my IRTE PARABOLIC, so what up (doc) any help (besides set it up in aussie) would be gratefully recieved,
DAVE.
PS HAVE IT WORKING REVERSED ie astra now in the west on my strong 4375, and hispa sat is well east.
Would sound like you have the power cable connectors reversed Dave.
Rolf
Burnt Chips
No big R: i just unbolted from the irte mount : and bolted onto C master mount. no wireing neccesary.(shit load of welding though)
4in pole on irte. Had to convert 2in pole C master to 4in.BUT unless
this pole has a (life force)its not the cause of me probs:
DAVE.
Burnt Chips
HI big R (cured it). A dude on (Phills) posted about mounts different
ie: 1 Pushing and other Pulling. And said to reverse polarity,I did and now alls well, (just in time for pervey channels)dragons gone to bed. (So you were right with your original diagnoses)IN A FUNNY SORT OF WAY. Dave.
PS for a change it cost me nowt just greef.
Good, glad you got your nightly mature content dose :)
Rolf
Converting post sizes is not the best way for stability in high winds
Are you still a non smoker BC ?
