help me with dm8000
jack10
like computers tech
oman
hi friends i have dm8000hd and i bought penthouse hd card and cam 9e-but when i inserted the cam nothing shown in dm8000-
slot- no module found
any help please
dm8000hd
gemini4.7
cccam2.1.4
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
what encryption is it ? Can you not use the internal card reader with CCcam instead of using a hardware cam ?
jack10
like computers tech
oman
dre-crypted system-i insert the card in slot but still not working
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Did you insert it the correct way up?
jack10
like computers tech
oman
yes friend with the cam the chip up without cam the chip is down like other card i used/and i tryed with diffrent image gemini4.2 oozoon nabilo but all same not working /maybe it need edit cccam config but i dont know penthouse information to put in the cccam config/waiting help
B16MCC
/var/tuxbox/config
You need to research the details of the card. What system does it use, and therefore does it need any specific entries in the CCcam.cfg
Changing your image will make no difference what so ever.
The biggest issue you have is finding out what the card is. Is it NDS, ViaAccess or what ?
When you know this you can build a CCcam.cfg to suite it.
jack10
like computers tech
oman
thanks alot 2 u (B16MCC and topper ) for trying 2 hlep me and as u said the changing of image dosnt make any diffrence/but i changed the flash image and everything is ok /
jack10
like computers tech
oman
friends can u help me with dm8000 i want to rename the movie that i recorded is there any plugin i have suomipoeka plugin but not support rename
B16MCC
/var/tuxbox/config
FTP in from your PC and rename the files.
jack10
like computers tech
oman
i tryed with dcc 1.10 but when i go to recordings it come this missage(recordings path not found) is there any diffrent prog tham dcc
Replay 2
Dream Box 8000
500 GB Samsung HDD
Sony DVD
Dubai, U.A.E.
There is a plugin for renaming titles.
