help need with quality on turksatm
jemey123
Motor Technomate TM-3000
london
Hi, we need more info I'm afraid in order to help.
its says:
Motorised Setup
Satellite: Turksat 2A-3A (42E)
Transponder: [1] 11962/V/3333/3/4
Diseqc Motor: Diseqc 1.2
Move: Stop
Move Fine: Stop
Motor Control: Press OK
Command Type: Go To Position
Strength: ---------------- 85%
Quality: -- 5%
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Jemey123 it is obvious to me that you are lacking in patience, that is probably the reason you are not receiving the channels that you want. Please understand you are a new member so of all your posts go into a moderation queue until vetted by a moderator or admin. It would be advisable to pick this up again tomorrow morning when most people are not in bed. It may be a small tweek required as there have been very strong winds the last few days. Who installed your dish an installer or you?
jemey123
london
Ohh, and an installer did..
jemey123
london
can you help me please
Mickha
North West
You need to change the transponder you are searching for try scanning in 11958 V 27500, this is on the West beam and should produce a good signal, providing your dish hasn't been knocked out of alignment by the weather.
http://www.lyngsat.com/Turksat-2A-3A.html
Topper
I am not an installer, but it could be lots of different things, a motorised install requires specialist equipment to tune up and improve signal. Is the dish accessible from where you are, do you need to use ladders to get to it? If you keep posting again before people have a chance to respond they will simply do what I am doing and go to bed, this is not an IM service
jemey123
london
how do i change the beam?
jemey123
london
yes you need ladders
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
highlight the transponder 11962/V/3333/3/4 with the remote and press ok and it should give you a list of transponders. find 11.919.v.24444. 3/4 when you have selected it you need to move the dish with the remote using the left and right buttons on the remote using the motor movement until the signal quality bar lights blue and yellow. when you have found it use the fine movement to peak the signal quality to above 75% until its at its maximum. now store the position by saving it. you could try reading the manual as this should tell you how to do this with pictures . you need plenty of patience but when you have found 1 sat you can then store the others around the arc to 20 or so giving you thousands of free channels. all this is dependant on your system is working correctly and has,nt been moved by the heavy winds ect
jemey123
london
okay thanks but i have been moving the dish for quite a while now but the quality is still 5%. maybe theres a mitake on the usals?
Mickha
North West
The transponder you have listed, 11962 V 3333, doesn't seem to exist, on 42E, so you're receiver is always goinfg to show 5%, which isn't a signal.
Try selecting a different frequency, as mentioned.
jemey123
london
Shall I just try loads?
Try using this frequency 11804V 24444 5/6
This carries CNN Turk and is active right now. Its also nice and strong
jemey123
london
I have a problem. Im searching on Turksat but its finding either english channels. Now its just finding radios but they are not Turkish
jemey123
london
Im trying the transponder you mentioned right now
jemey123
london
I have tried the transponder you mentioned and i have now got 97% quality. What shall I do now?
Mickha
North West
Please list the channels you can view, check the onscreen logos, list the frequency, polarity and S/R, e.g. 12130 V 27500
gibertini
up north
53.6N 2.4W
store the satellite postion
Have you ever received channels off this satellite in the past ?
If so, which ones ?
Can you take a good couple of images of the outdoor equipment and post them here ?
