SKYLINEGT81
- May 21, 2009
- Age
- 44
Amd 5600+
Dfi lan party
4 gb 800 mhz Ram
2 TB hard disk
- Tharmad
Hi
I have try flash my DM600 using this method
1. Boot the box, goto the communication menu and note the ip address.
2. Run DCC, connect to the dreambox. Once the network is connected ok, click on the the 'Telnet' option.
3. In the telnet window, type the following, pressing <return> at the end of each line.
mount /boot -o remount,rw
rm /boot/*
reboot
4. You should now get a message saying that the Dreambox is rebooting.
5. Wait a few seconds and then run Explorer (Firefox or whatever) and enter the ip address of the Dreambox in the address bar.
6. On the screen that appears, choose the 'Upgrade firmware' option, find the .nfi file and click the 'Flash' button.
7. Once the progress bar reaches 100%, reboot the box
But I could not connect to the my DM600 on step 5
I try to get the IP from DCC no use then I used Serial Port method with Flash up same thing I could not connect to my DM600.
Help Please
rm /boot/*
reboot
Help Please
