robpegs
- Aug 30, 2008
- Age
- 53
- TN5400 80CM
- Bath,England
Hi all, a few questions that i hope some one has the answer to.
Ok I have a tm5400 ci+ usb, fully patched and new softcam keys installed,my first question is,I'm able to decode most, if not all nagravision channel, but not luck with any others i.e viaccess,seca and so on, so with a softcam/patch installed should this receiver decode viaccess etc,with valid keys..I understand the tm-5400 has a multicrypt card reader (Multicrypt Card ReaderDigitAlb, Conax, Iredeto, Viaccess 1 & 2, Original ART Card, Greak Nova Card) and 1 ci slot,
so wonder why the softcam is not decoding?and if i was going to buy a cam for this box,what one would be best? and can the keys be used the same was as a if i was using a soft cam? or would i need a card and programmer.
thanks in advance..
Rob
thanks in advance..
Rob
