theorange
- Jan 11, 2006
- Age
- 44
- N/a
- west midlands
Hello All
I have a technomate tm-1500 ci+ super, along with a tecnomate diseqc motor and 90cm dish.
The kits been up and running since Friday and today I decided to have a fiddle with the Patch CD software that came with the kit i bought of ebay.
I installed the CD (tried it about 3 times installiation). I also downloaded the new software from the technomate website. I used the com cable supplied and attached it to my computer and sat box
Now, I have the problem of 'No or Bad Signal' on everything on West satellites
I usually watch the NBC feed on 15 degrees west - Now I've got nothing and its 7% - Now i get about 3 seconds and then a break up and nothing, and nothing on anything westwards after that.
15w - no signal on any feeds
30w - no signal on any feeds
1w - no signal on any feeds
5e - Works fine
13e - Works fine
16e - Works fine
19.2e - Works fine
28.2e - Works fine
It seems my dish wont get any signal on west feeds. Whats wrong?
Please help
5e - Works fine
13e - Works fine
16e - Works fine
19.2e - Works fine
28.2e - Works fine
Please help
