Hispasat 30W-6 / 36W-1 / Amazonas 5
I am getting a test card at 36west on11330H 3000. Not sure if this is Eutelsat or Hispasat.
It reads Ident Mode
It is Eutelsat
FlySat Eutelsat 36 West A @ 36° West
Eutelsat 36 West A @ 36° West / Atlantic Bird-1 that used to be @12.5 west is holding this position for Hispasat 36W-1
(Hispasat AG1) that is currently here on another mission at 37.6 west.
HISPASAT 36W-1
NORAD ID:
41942
LOCAL TIME:
19:11:28
UTC:
18:11:28
LATITUDE:
0.03
LONGITUDE:
-37.63
ALTITUDE [km]:
35865.97
ALTITUDE [mi]:
22286.08
SPEED [km/s]:
3.07
SPEED [mi/s]:
1.91
AZIMUTH: 224.6 SW
ELEVATION:
+21.3
RIGHT ASCENSION:
07h 28m 08s
DECLINATION:
-08° 10' 47''
Local Sidereal Time:
10h 14m 15s
The satellite is in day light
According TLE, two days ago Hispasat 36W-1 has arrived at 35.8°W.
Laser
Just had a scan of Hispasat 36 West. Managed to see Canal Moncloa. Not sure if a feed or not ...However signal is 93%..17dB ....SQ compared to 80SQ for the Test Card on 11330H 300o 1/2.
Canal Moncloa is on 11396V 9600. I suspect a feed but on new satellite?
There is also a lot of data activity also around 11450V -11900V
Everything between 11.3 and 11.45 GHz will be Eutelsat 36WA.
While 11.45...12.2 & 12.5...12.75 GHz is likely Hispasat 36W-1.
Press release of May 26: Hispasat
By the way, the old Hispasat 1C (lately called Hispasat 84W-1) is going to graveyard orbit right now.
anto@
italy
I have scanned for the new satellite only active here atm is for Eutelsat 36 West A @ 36° West
Hispasat 36W-1
11468 v 14260 7/8 DVB-S very strong signal but no lock so looks like a test carrier ?
Tururu
Assembled with recycled parts
Recycled as the owner.
Some fishing/Unas pescas.
The ever new links/La de siempre mas nuevos enlaces.
Are all of Hispasat36W-1 ??/Son todos de Hispasat36W-1 ??
11468 V 14261 FEC:AUTO DVB-S
There is no channel name, no video/audio PID.
En Busqueda ciega, lo marca con FEC auto.
Busqueda manual igual con FEC:7/8 en los 2 casos, no le gusta nada, tarda 1 minuto.
In blind search, mark it with auto FEC.
Manual Search equal to FEC: 7/8 in both cases, does not like anything, it takes 1 minute.
Hispasat 36W-1
Indeed,the signal is strong on this transponder,but is not a test carrier,but Data.It's on Intelsat 903.
Tururu
True, the signal is very strong, filtering to 2º the tuning/Cierto, la señal es muy fuerte, filtrando a 2º lo sintonizo.
Just reinstated Intel-903 @ 34.5 west having used this slot for 36 west & can now see the data stream now on 11468 V :)
I think 36 west will have some feeds for Real Madrid vs Juventus Champions League Final 7:45 KO
12179 H 3000 test carrier active for a few minutes
Tururu
You can, who knows.
The most certain thing is that they emit by where always.
Eutelsat 10ºE, 4K (UHD) in Biss and as it is well known, recently in 4:2:2.
All recectors "liquidated".:-doh
PC cards.:)
Puede, quien sabe.
Lo mas seguro es que emitan por donde siempre.
Eutelsat 10ºE, 4K (UHD) en Biss y como es muy conocida, desde hace poco en 4:2:2.
Todos los recectores "liquidados".:-doh
Las PC card.:)
I'll watch it on DTT2 (DVB-T2) on Antena3 4K channel (Cellnex and Atresmedia tests) if there are no changes out of curiosity, I'll leave a monitor on the channel.
Lo vere por TDT2 (DVB-T2) en el canal Antena3 4K (pruebas Cellnex y Atresmedia) si no hay cambios por curiosidad, dejare un monitor en el canal.
PS: Play the "Forbidden Planet" during the match/toca el "Planeta Prohibido" durante el partido. :-rofl2
FIG World Challenge Cup 2017 Rhythmic Gymnastics
36 west 11395 V 9600
id=E =96 Via 1
World Paddle Tour (Bit like tennis)
11419 V 9600 HD
Overon feed
Irish type Football
11371 H 4800
Overon feed
Aqui Galicia
11382 H 7200
Laser
Almost forgotten about this one. Launched in January. I guess not intended for general full time TV. Have seen a few feeds. I guess maybe for government work etc?
With a new Hispasat 30W-6 to launch to 30West end of year seems unlikely for full time TV.. Any thoughts??
The Hispasat 30W-6 (Hispasat 1F), to be located at 30º W and will serve as a replacement for the Hispasat 1D, will give the Group additional Ku band capacity, in the Andean region and in Brazil. Likewise, the Hispasat 30W-6 (Hispasat 1F) will expand the Group's transatlantic capacity in Europe-America and America-Europe connectivity. C band capacity with American coverage and Ka band capacity with European coverage will furthermore be incorporated, in order to enable HISPASAT to continue expanding its broadband service offer in the region.
Hispasat 30W-6
The Hispasat 30W-4 (Hispasat 1D) satellite, will probably move to 36 west allowing Eutelsat 36 West A / Atlantic Bird-1 to either retire or for use as an elliptical orbit use.
Laser
Thanks William-1 So what do you think will happen to Hispasat 36W-1 in the short to medium term?
