humax 5400 question
psats
da95649 said:
Hi Psats, just very quickly, the bin files, where do you generally get them from, all the sites I know have specific files like TIT, DS9 , 6-1, can I use any of these BINS? As I have no card I dont know what one to use.
Also while I upload the bin to the receiver the card that I have inside is a very old silver Fun card that used to work is that okay?
da95649
you can get bin files from the likes of mach1 usualy in his files
or from here
h**p://free-bj.htnet.hr/papagen/files/PapagenRam.zip
psats
da95649 said:
So is the Samsung box exactly the same as the Humax 5400?
no they just use the same bin file
you have all the stuff now to upgrade so good veiwing
da95649
dam Im going to print this thread and pin it to my wall.
Psats I couldnt thank you any more!!!
psats
if you need help just ask
psats
da95649
psats
Hi there,
ok I uploaded the patch ok, I uploaded the file ok, however Im using Humbox 4.1 and HNFsmart to upload the lastest HB settings, however its saying connecting to the box but it stops. The com port is correct and the speed is okay, I tried from Box to PC and that works....any idea?
da95649
what im doing is loading the channel hnf file swithcing the STB off, press transfer then the PC to STB box try to connect, swith the box on, and it says transfering however the STB says E - Id??
any idea?
psats
any idea?
hi recheck the setting in edit options model sounds like its set to wrong one
mines set to {00160000}
check against your info in the receiver
CHERENNO
psats said:
If your humax is a ver that is patched.?if you were useing a ds9card IT IS so all you will need is a new chnl list and the new hot patch its got a emulator for s2
the new patch is + ToH 3.3 hot
knotcard...NO
cams......NO
just repatch the hummy
work with humax 5900???????
psats
i have not got a 5900 so i cant commment but what ive read on other sites NO
da95649
I have patched it with 3.3 and i just done an antenna search for now, however Im having trouble uploading the new bin file i got which is papgenRam, Im using DSR, but when I right it goes to 100% with or with the lead, therefore I dont think its writing to the STB succesfully.
psats
did you set it for humax the dsr in the ? plus the receiver is best on a fta chnl and make sure the card is in the slot ok.
upload the bin then turn rec off via remote then back on
CHERENNO
i
have mannhatten 2500 and humax 5900 and matrix modul can i got sky on hotbird 13
da95649
Hi PSAT,
can you confirm what step by step what i need to do in DSR EMU, is it Read or write??
psats
da95649 said:
Hi PSAT,
oen dsr check its set for humax def
openwhere bin is load bin then right to hummy
?have you been to menu toh config caid preset and set it to card+emu..?
