Ideal size for exploring
I did think about that, but I wouldn’t be able to adjust the “vertical ness” if that’s a word… of the pole if it was on uneven grass.
Four long bolts (or threaded rod) through the bottom of the slab, one nut and big washer to attach the bolt to the slab, wind on another nut & washer and then put the post on, the second nuts can then be used to adjust the plumbness.
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
StrongSat FTA Reciever
80cm Dish + 45cm Dish via Disecq A/B.
England
I think @ozumo’s suggestion. Sounds like a winner.
I did try out the motor last night, worked at first although very noisy compared to my other, now doesn’t turn, lights up though. Left it overnight no change, was only able to make a minor step manually but nothing more. Dunno if it’s dead or needs some kind of hard reset
Hope it's not dead - it had hardly been used! I do vaguely remember having to be particularly diligent about the integrity of the cable connections.
I'm more concerned he will drive back oop north..
Which motor is it ?
It's badged Fortec Star but is clearly a Motek clone.
I think the cable core receptacle on the Rx to Motor socket was a wee bit too wide so the cable core needed to be flexed sideways to enable good contact. Long time since I used it, so memory is hazy. Maybe bung a bit of foil or summat in there to pad the gap?
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
I made a new cable using higher gauge coaxial and that didn't make much difference, I could get the motor to click but not actually move. Abandoning motor for now until better weather in favour of perhaps getting an adjustable multi-lnb bracket (or 3d printing one as it doesn't seem to be very sophisticated).
In other news, I've managed to convince my wife that chopping down a dead tree and mounting the satellite dish behind a bush in a flower bed is ok. For that I'm thinking, fence post very deep concreted in, TK bracket on fence post with dish hanging off. (I think it'll be more sturdy than a 2" pole going directly into ground and concreted in.
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
This is a dish i had once mounted on a scaffold pole, i used a paving slab staked to the ground. the pole had a plate on the end with four holes which i fixed to the slab with rawl bolts/studs so i could get the pole plumb. It needed the guy ropes to stop the pole swaying in high winds this setup was trouble free, when i upgraded to a 3 inch pole i concreted 4 studs into the ground for fixing.
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
I am considering mounting a TK Bracket to a dead but not rotten tree I have and going that route, having a think ;)
EDIT: Just bought a fence post and 750mm spike (I cannot concrete it in right now as I'll be moving it potentially from time to time). I plan on having it almost ground level, so hopefully not much movement possible.
D4ftpunk
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
well, with a TK Bracket, (should have taken @Lazarus 's) a fence post in a spike, a pole rammed about 1 meter into the earth... and a dead tree chopped down it seems pretty stable. if it holds up well for the next few days of wind and rain I'm gonna put the Triax 110 dish on there permanently (which is quite heavy).sat.jpg
Nice work! Yes, sadly I've now binned those spare brackets so could't even fax them to you :unsure
