ash213
- Jul 30, 2007
- Age
- 39
- DM800HD, INVERTO Silver Tech Universal Twin LNB 0.2, Technomate 80cm mesh dish
- BRISTOL
Thanks in advance!
basically ive had this set up running for 2 years simply pointing to 1w to pick up some football on saturdays. this year ive decided to go motorised.
the current set up has not messed up once, not moved etc...thankfully (check the pics)
i am very proud of this set up as i had never done anything like it before!! im about to take it down, well take the dish down in prep for the new set up with the motor.
anyway just wondering if theres a guide to put the motor on as easy as poss? im very scared to do it as i dont wanna mess anything up.
with my set up will it be ok with a motor and how do i know if the current position will pick up all satellites??
please advise as i am to fit the motor some time this week .
cheers
cheers
