ash213
- Jul 30, 2007
- Age
- 39
- DM800HD, INVERTO Silver Tech Universal Twin LNB 0.2, Technomate 80cm mesh dish
- BRISTOL
Tivù said:As you've done a Factory Reset, you'll need to send the motor to zero (There should be an option for that), re-enter the USALS coordinates given earlier, then select 1W.
You will need to alter the dish up/down a tad from the initial 22, as well as slowly rotating the entire dish/motor around the pole in order to locate the reference Satellite.
Same as aligning a fixed dish, except you treat the motor as part of the dish.
It's all in the Motor Instruction leaflet and the Forum Sticky Guides.
If I were you, I'd have a break, read all the bumph again, then go in for one last push!
I think you are probably nearly there: But please Post some pics so we can check for obvious mistakes.
Are you using a Satellite Finder or are you relying on your Receiver?
Use BBC World on 11325 H 24500 7/8 as that is a strong signal.
this is a great post.
im leaving it all till tomorow morning now.
too stressed lol!
when im searching on 1w you think transponder 11325 H is best to set it to?
im not using a sat finder, simply relying on me moving the dish and the wife indoors shouting out about signals! yes im a proper budget monkey!
