I'm Sooooo Odiot.......!!!
mariosk1gr
Skymaster Dish 80cm with skystar 2.
Intel Q6600 - 4GB Ram - Asus Maximus Formula - XFX 8800GTS 640MB Alpha Dog Edition - Vista x64
Greece
Hi everyone,
yesterday I bought skystar 2 and as I saw at "idiot guides" I downloaded ProgDVB 6.02 and DVBviewer PRO 3.9.4.0, so I am trying to use these programs with "softcam.17.dec.2008" which I downloaded but I don't know how!! I downloaded the latest version from Yankse-1-31.0-TT-XP but it doesn't work cause I have vista x64.
I'm completely idiot cause I have search so much for a guide to use softcam keys and software and I don't have understand nothing!
If someone know and have time please send me a simple guide about
PROGDVB or DVBVIEWER.
Merry Christmas to EveryONE!!
iandoh
Pärnu. Estonia/Burgas, Bulgaria
1m Mutlibracket (19e, 13e, 10e, 9e, 4.8e) & 1.2m @ 28e
mariosk1gr said:
Hi everyone,
Download vPlugin with latest keys, its much better and easier to use, just install it to the DIR of ProgDVB plugins and it will work.
mariosk1gr
Greece
Ok So do u know where can i find it?? I tried dvbsoft.net but no luck.
When I download it I just put it only to progDVB dir?? no settings?
Thanks in advance my friend iandoh!
HB13DISH
Retired Mod
Middle East - Israel
Which satellites are you pointing to?
I suppose Hot Bird 13E judging from your location.
Perhaps I am mistaken, but AFAIK there is nothing there worth the trouble.
Best to go to vplug's main site -
_http://vplug.baywords.com/
Yes, just put it in the ProgDVB's plugin folder. You'll need to update v_keys, search for the latest one.
mariosk1gr
Greece
Yes I'm pointing at Hotbird 13o East.
Ok So I uninstalled everything cause was a mess and started from the
beginning!
So,
1. I Installed ProgDVB 6.02 x64.
2. I put into "plugins" folder v_keys.db (3/12/08).
3. I installed vplug 2.3.9
4. I put into "plugins" folder softcam.key (17/12/08).
Final: Do I need something else to do???
Very many thanks for ur help guys, be well!
mariosk1gr
Greece
So, can someone (plzzzzz) tell me where am I wrong??
As u have seen in the preview msg I have done these steps that u have told me to do. Am I missing something with the settings on ProgBVD 6.02? A little help if u can guys...
Click on the Plugins tab when you start ProDVB and tick vplug and monitor.
Haven't checked lately, but as has been mentioned, not much you can clear on 13E now.
HB13DISH
Retired Mod
There is nothing on Hot Bird 13E.
Which channels are you after?
mariosk1gr
Greece
As I have checked in my country most people set their dishes to 2 specific satellites: Astra and Hotbird.
So u tell me that ProgDVB and plugins can't u***ck channels on hotbird!
Damn it, I don't know if I can set my dish to another satellites cause I don't know if it is possible to do from my country (Greecce)...
Until now I'm watching only fta channels and I'm trying to see movie channels like nova - filmnet - supersport and others. Guys can u suggest me a solution plz........? I'm Lost for one more time again!!!
Sotos65
Receivers: Edision Argus, Technomate TM-5300D+ USB, Skystar HD2
Dish: Tecatel 1.10X1.20
LNB: Sharp BS1REL100W
Sat motor: Moteck SG2100
PC: Cpu C2D E8400, 2GB.
Greece
Unless you have obstacles (trees, buildings) in front of your dish, there is nothing to prevent you to set it up on another satellite.
I guess you're out of luck! There is not much left to see with plugins like vplug (or with emus on set top boxes) at this time. The only important package that is left "open" is "Digi TV" on Thor/Intelsat 7-10 at 1°W.
mariosk1gr
Greece
Ela re Soto epitelous enas ellhnas na sunennoitho san anthrwpos!!!
Na sou pw file mou efoson vevaia den ginomai "varos", mporeis na mou eksigiseis peripou pws doulevei to susthma me thn skystar 2 k to xekleidwma tvn kanaliwn? H alhtheia einai oti exw ena poly fthno piato 80cm to opoio to eixa parei set me enan apokodikopoihth ths plakas k epeidh prosfata anevasa to piato sth taratsa k perasa to shma se oles tis prizes tou spitiou skefthka na parw th sygkekrimeni karta gia na vlepw dwrean ta apokodikopoihmena...
Apo oti diavasa se forum ke meta apo poli psaksimo eida oti h skystar exei autes tis "dunatothtes" opote k proxwrhsa stin agora tis!
Telos olo auti to epixeirhsa skeptomenos me to "xazo" mou to myalo oti tha vlepw tainies mias pou eimai cinefil, podosfairo kana ntokumanter k.a.
Kai se rwtaw egw twra: is it possible???
Sotos65
Greece
Είναι δυνατό (το vplug δουλεύει ή μάλλον δούλευε πολύ καλά, και δεν έχει να κάνει με δυνατότητες της συγκεκριμένης κάρτας μόνο, δουλεύει και με άλλες κάρτες, αλλά με τα διάφορα προγράμματα που χρησιμοποιούμε), αλλά έπεσες στην περίοδο των ισχνών αγελάδων που σχεδόν όλα τα πακέτα (Premiere, Polsat πήγαν σε nagravision 3, TPS φεύγει από Hotbird και πάει στον Astra με αλλαγή κωδικοποίησης, κλπ) έχουν κλείσει το τελευταίο δίμηνο! Κάποια σκόρπια έμειναν εδώ και εκεί, αλλά τίποτα το αξιόλογο εκτός από το Digi TV που μάλλον κι αυτό θα περάσει σε nagravision 3 κάποια στιγμή.
PS. Sorry for the greek!
Enough already - English in this section please.
mariosk1gr
Greece
Sorry for the greek.
If I have understand correct, nagravision, TPS, seca and others are decryption systems to secure the channels right? So where to put my dish u suggest??
What do u think about NOVA? Can it be??
HB13DISH
Retired Mod
No, TPS is a French package and it will leave Hot Bird 13E by the end of this year. Nagravision, Seca are encryption systems.
Nova is secured with Irdeto.
mariosk1gr
Greece
mariosk1gr
Greece
Ok I fixed by installing 32bit version, for some reason 64bit doesn't play!
So, until now I have put many plugins into "plugins folder" but how can I know what have I un****ed??
Take a look:
I have lost plz a little help guys........
So many channels..... How shall I know if i have done anything???
mariosk1gr
Greece
SOTOS65 if u can send me ur email to contact with u if u like.
Too much unwanted files in your Plugins.
You only need those I have in the snapshot.
The channels with a red icon are the encrypted ones. The only encrypted channel I can open on 13E is the one in the pic. Possibly it's clear ATM anyway :-rofl2
Forget 13E, nothing doing now.
