Sotos65
- Nov 12, 2008
- Age
- 59
Receivers: Edision Argus, Technomate TM-5300D+ USB, Skystar HD2
Dish: Tecatel 1.10X1.20
LNB: Sharp BS1REL100W
Sat motor: Moteck SG2100
PC: Cpu C2D E8400, 2GB.
- Greece
Actually you don't need all those files in every application (AltDVB, Progdvb, DVBViewer, etc), you only need two, vplug.dll and vplug.ini.
You install vplug in a separate folder (anywhere you like, the default is C:\dvbapps\vplug) and you only need to copy those two files in the dvb application plugins folder. There is just one more thing to be done, you have to edit vplug.ini (with a simple text editor, like notepad) and put the vplug's installation path in "FilesPath=" (without quotes), like this for example,
FilesPath=E:\DVB\vplug
Anyway, as others have already said, there is not much to see (at least on Hotbird).
