Irish FTV Card
tomthebomb1968
VU+ Duo 250gig/ DreamElite BH 1.3.2 Multiboot
Dreambox 500s-(clone) / DM-600
Relook 400s 160 Gig-/SifTeam 1.93 e enigma
Foretec 90cm Dish with Nikkai Diseqc Motor- 2 sky+ receivers fixed 28.2 east.
Newtownabbey, near Belfast, Northern Ireland
Their must be multi-spot beams. How could Donegal get the same beam as Dublin and not Belfast?
jordie
sky hd
spiderbox 9000hd with motorised dish.
Derry/Donegal
i phoned up sky and they said you cant get rte with a n ire ftv card, they said you need to pay for the basic package
JTA
DM8000HD+DM7000S with PLi image, CCcam, movable dish 0.85 m, very happy indeed
Belgium
if you need to pay for the basic package then it's a subscription, not FTV.
with a FTV card you can continue to watch even when the subsctription ends - this is not the case with the RTE channels. They are part of the basic package you need to subscribe to (in Ireland)
tomthebomb1968
Ok guys what has been written by some posters has not been what I have experienced in the past. I personally have cancelled Sky subs in the past and the card has become a FTV card allowing me to watch RTE1/RTE2 and TG4. So this morning I contacted Sky to find out if it is still possible to view these channels freely in Northern Ireland.
The answer is YES but the situation changed a bit after May 08. A lapsed Sky NI card will still open the Southern channels, but they disappear from the EPG, all you need to do is manually scan them in. If you dont have a lapsed sky sub card you can get a FReesat from Sky Northern Ireland card for £25 and again this will open the channels, again manual tuning is required..
This was the situation at 0950 hrs today according to the sky rep I was speaking to.
jordie
sky hd
Derry/Donegal
That would explain it then, alough there seems to be conflicting views from sky. I got the same answer from sky, they told me it had to be manually tuned but when I did this they are still blocked.
Does anyone have the frequencies in case im using old ones?
Aye, there is some sense in what Mr.Bomb says, but can we rely upon Sky CS?
AFAIK, there's only one set of frequencies in use.
Now this is strange. Presumably you have a subs card and it's a NI one? Has it expired or is it still current? ALthough this should not make a difference from what Tom says.
jordie
sky hd
Derry/Donegal
no its still in full use registered to ni address
I suggest you get back in touch with $ly.
Incidentally, from what Tom says, with a valid subs card surely you should have these channels in the EPG?
pajo100
1.2 /1.8 Channel Master fully 36v motorised 58west to 42east Pace MSS500 Positioner
,Technomate 6900 Super HD ,Humax 8100PVR oh and a Amstrad Sky+ digibox.
Ireland
They must be blocked in some way as Rep. of Ireland subscribers can not access UTV on the EPG and have to tune it in manually. RTE etc start at channel 101 on irish subs.
robbiemcd
technomate 6800 +diablo - im motorised dish
belfast
just tried this with my ni freesat from sky card - i can confirm c4 hd and c5 hd open but no rte! deffo - even tried scanning them in and found tv3 but nonw will open
robbiemcd said:
... freesat from sky card - i can confirm ... c5 hd open
You're absolutely sure of that? If so it's either a special NI thing or they've made a mistake. Can you view ITV2 HD?
robbiemcd
belfast
yes no itv 2 hd and no rte!
C5 is no surprise - NI cards are mapped to the fta verson on 2D :D
robbiemcd says that he gets C5 HD, not just the vanilla variety. ;)
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
C5 HD is FTV, why whouldn't he get it?
Because C5 HD isn't FTV. It's supposedly only available on at least a minimum $ly subscription - unless that's now been changed.
C4 HD is FTV
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
C4 HD is FTV
Ah yes, sorry, you are right of course. I was getting mixed up with FTV and non-"HD pack" HD channels...
pajo100
Ireland
C4 HD is FTV
Yes it has as Ch 5 HD insisted on it being FTV for a indefinite time probably hoping after that peeps will subscribe to it like ITV2 HD.
So you're saying C5 HD is FTV not minimum subs?
I don't have a $ly receiver so am only going on what I've read. Can anyone else confirm that C5 HD is encrypted to FTV level?
