Is there CAM to get skytv on DVB-S tuner card?
daveyboyc
Enquiring about setup using multiple satelitte a dvb-t tuners
london
Fair enough.
Still, if anyone out there has a phoenix card reader and a card and is willing to give it a go, i will offer them £50 for the effort.
daveyboyc
london
OK, aside from offline descrambler (im asking the programmer about that). Does anybody know the correct way of getting the boxid for NDSCAM 0.0.0.7 ? I have tried a few differnet numbers (namely the ones that were displayed in the ndscam monitor) and every time i tried to enter them they disabled the emu completely. How do i know which is the correct one? I heard doing this might allow me to get the s sports channels, i can get one of them on a different transponder from the one in the dvbviewer channel list (maybe i can get them all on a diff transponder..)
Any help is really really apreciated. Thanks
The best solution to open your premium channels will most likely be to install Cccam on a Linux distro within some VMware e.g Virtualbox on your host PC.
I already have Virtualbox running on a PC with Linux as the image. Just need to add the Cccam and run it with something like ACamd to access the Phoenix smartcard to see if that works (I now have a Premium sub - Racing UK) - which I have resubscribed to.)
daveyboyc
london
Hi again LLew,
Thanks for the info. Is there any way i can get CCCam with Windows? I tried Hadu but cant get it to work so far.
Are you able to record multiple channels with that setup? I read that some people have dreamboxs setup where they can record multiple premimum channels at the same time (with 1 card). This is what i need.
If you're a betting man (which you might be with racing uk) would you bet on slysports working on the setup you have currently?
Cheers
daveyboyc
london
Got premiums working with acamd! sweet!
Nice one :)
Can you give me a run-down on your configuration - I've lost the plot :eek:
ASTRO Satellite Pay TV
Malaysia
Llew said:
The card reader needs a serial interface to work with NDSCam, so that one is not suitable.
Not easy to find one nowadays, the best I could find on a quick search is one from a German supplier -
_http://www.satshop.tv/Smartmose-Phoenix-357MHz-600MHz-Programmer-USB-Power
Actually the tbs3102 has a built in USB->serial interface. The computer sees it as a com port when plugged in. so it should work with NDSCam. I havent tried it though I have just bought it.
My question is how do i know which settings to use? NDSCam asks for pheonix reader, but do I use 3.3v or 5v?
Which crystal do i use? there are the choices of 3.579MHz with 6MHz, 8MHz, 10MHz and 3.686MHz (Y5). how do i know which one to use?
I plan to use it with Alaysia) which is NDS 09ac
I think the voltage will depend on your version of the NDS card, 5V is the norm. Crystal freqiency is 3.579MHz.
NDSCam is configured to access a COM port of your PC, not through the USB port, might not work with your reader.
daveyboyc
london
Forget about NDSCAM, it doesnt work very well and you cant watch the sub channels. I have the TBS card reader aswell along with a serial card reader (which ive ditched). Use NewCS and acamd instead, its much much more stable.
KuchKuch
Core 2 Duo E6650
4GB DDR2 RAM
I have been having a lot of problems with NDScam since early December. Most of the times I can't decrypt any of the encrypted channels and when it does encrypt it only seems to be work for about 30 seconds before the picture and sound freeze.
Is there a guide somewhere on how I can get NewCD and ACamd setup in DVBViewer.
PS: Daveyboyc, I just got your PM, don't think its worth much now as you seem to have got everything setup.
KuchKuch
Core 2 Duo E6650
4GB DDR2 RAM
It's now gotten to the point where NDScam doesn't seem to want to work ever. I have been trying for the last two days to decrypt encrypted channels with no luck. I'm hoping the log file for my NDScam will give someone an idea to whyNDScam is not working.
11:20:54.780 |//////////////////////////////////////////////
11:20:54.780 |// NDSCam ver. 0.0.0.7 by Joker
11:20:54.780 |MD-API Version 01.02
11:20:54.780 |TT-tricking OFF
11:20:54.780 |Auto baud rate detection ON
11:20:54.781 |BoxID auto detection ON
11:20:54.781 |Phoenix reader selected in port COM1.
11:20:57.036 |Host is changing the channel.
11:20:57.037 |Restart requested.
11:20:57.038 |Restarting using: ChName=Sky1, SID=3869 (0x0F1D), LNB/DiSEqC=0, CAID=2400 (0x0960) NDS, ECM=1283 (0x0503), EMM=0 (0x0000), CA Count=9
11:20:57.038 |Opening COM1.
11:20:57.045 |Reseting COM port.
11:20:57.215 |--------------------------------------------------------------------------------
11:20:57.215 |	  >> Reseting card and analyzing ATR <<
11:20:57.216 |--------------------------------------------------------------------------------
11:20:57.966 |Error: Can't recognise ATR.
11:20:57.966 |Please check your reader or make sure that your card is inserted and restart.
11:20:57.966 |Error: Card NOT supported or invalid ATR.
11:20:57.966 |(Phoenix)Error: Can't reset your Card !
11:20:57.966 |Error: Problem reseting reader. Stopping NDSCam.
11:21:11.522 |/////////////////////////////////////////////////
11:21:11.522 |// NDSCam is enabled! Restarting...
11:21:11.524 |Restart requested.
11:21:11.525 |Restarting using: ChName=Sky1, SID=3869 (0x0F1D), LNB/DiSEqC=0, CAID=2400 (0x0960) NDS, ECM=1283 (0x0503), EMM=0 (0x0000), CA Count=9
11:21:11.525 |Closing COM1 port.
11:21:11.537 |Opening COM1.
11:21:11.538 |Reseting COM port.
11:21:11.709 |--------------------------------------------------------------------------------
11:21:11.709 |	  >> Reseting card and analyzing ATR <<
11:21:11.710 |--------------------------------------------------------------------------------
11:21:12.460 |Error: Can't recognise ATR.
11:21:12.460 |Please check your reader or make sure that your card is inserted and restart.
11:21:12.460 |Error: Card NOT supported or invalid ATR.
11:21:12.461 |(Phoenix)Error: Can't reset your Card !
11:21:12.461 |Error: Problem reseting reader. Stopping NDSCam.
11:21:21.510 |Main application is trying to unload NDSCam.
11:21:21.965 |Closing COM1 port.
11:21:21.976 |//////////////////////////////////////////////
11:21:21.977 |// NDSCam stopped.
11:21:21.977 |//////////////////////////////////////////////
daveyboyc
london
yeah NDScam is crap mate. just delete it.
download newcs and acamd(newcs needs to be saved somewhere like on your desktop and acamd in the "plugins" folder - MDplugins not necessary). im not really an expert but there are guides and helpful people out there that can get it working for you, they might be hard to find though as that kind of chit chat isnt exactly welcomed on most of the forums, so you might need to PM people to get info...
