Is this dish ok?
garyg
garygoodger.com
Nothing at the moment :(
I was after a 2.4M channel master, and someone told me they have a 2.5M channel master... picture attached.
As most know its for 26e badr6, the 1.8m gets signal but any rain and its going to go! its very low.
Will the attached dish do it, can anyone confirm its a channel master??
Regards
Barry Young
2.4m dish + an 80cm dish with twin LNBs. 800HD Dreambox.
Costa Blanca Spain.
Regards
Hey Gary, That mounting does not look good. If you go for it, try and get some info about a better stand. My stand on the 2.4mt dish, is probably 4 times the diameter of the one that that dish is mounted on.
My neighbours dish blew over in a gale, it had a very poorly constructed base and his dish had to be replaced. I have a 1mt x 1mt x 35cm thick base and that's fine.
garyg
garygoodger.com
Thanks mate i will take note, but does the dish itself look ok? Its advertised as a channel master, but not 1 i have seen?
I just want to know its up to scratch and wont perform worse then my 1.8! lol
I was thinking of concreting the 4 stand bits into the ground, that should hold it in?
garyg
garygoodger.com
Can anyone confirm its a channel master?
Does look like one from the back.
Also how does it perfeorm? Its 4 pieces? Does that effect it?
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
It is a channel master I have seen one of these before. Unfortunately it was laid on the floor and not operational so have no idea how well it performed.
Get a closer look at the feedhorn to see if its ok and that it will take an invacom C120 LNB
garyg
garygoodger.com
Ok mate,
If it takes the c120 you think i should take it?
garyg
garygoodger.com
I cannot find any info on these dishes anywhere, how they perform? Quality etc. :(
Also, every picture i see of dishes like this they appear to be pointing really high into the sky?? Is it just the location/satellite or do these dishes really point that upwards?
wod
yorkshire
well it will perform well as channel master are good quality, this looks to be one of there prime focus models which could be in 4 panels that you bolt together.
the model you have outside in your garden is offset which means the dish recieves the signal at an angle of 26 degrees etc which is what the offset means. prime focus point up in to the sky direct at the satellite.
your really going at some length to make sure you receive all the epl games on a weekend.
_http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130399177557&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2F%3F_from%3DR40%26_trksid%3Dp3907.m570.l1313%26_nkw%3D130399177557%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1
With a prime focus dish the satellite, LNB and centre of the dish face are in a dead straight line. With an offset dish the LNB is lower than the dish face and the satellite is above. This gives the impression that the offset dish is pointing lower but in reality they are both pointing in the same direction.
garyg
garygoodger.com
Ah i see! i did wonder!
As for the ebay link, yeh thats the one the guy got it but its to heavy for his roof, so im getting it £500 delivered.
As for the dish performance etc, correct :D its the 4 panels bolted together and a channel master.
Will it perform as well as the 2.4M channel master 2 piece dish? And do these prime focus dishes, do they perform as good?
Sorry but this is a new eara to satellite for me!! (as if i havent had to learn enough already in the past 5 years)!
Thanks for the help guys :)
If you get the alignment nailed that's going to be one cool motorised setup.
garyg
garygoodger.com
Cheers mate but I will for now just aim for 26E and ADMC.
Another thing, because its prime focus and points up more can it go closer to the ground or am i wrong?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The closeness to the ground is exactly the same as an offset dish, but the top of the dish will be lower, as its leaning backwards of course, so less visible from outside the garden.
The effective height of a 2.4m dish when aligned to 26E will be approx 2.2m. Wheras a 2.4m offset will be approx 2.6m high.
The important thing is is can the bottom of the dish face be seen from the satellite over any obstruction. That's going to be the same for both kinds of dish. PF dish face points up at a steeper angle but both receive from exactly the same point in the sky and both need a clear view to the satellite.
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
its a channel master alright i instaled a similar one few years back ,,the dish is made of fiber glass and will last for monks very solid stuff...the only problem you will have is the lnb support and feedhorn and may be the rienforcement at the back as it look a bit used thru the years..good luck m8
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
could it be also a northern satellite oem dish?,with the same size?
garyg
garygoodger.com
Cheers guys! hopefully the mount that comes with it can clear the wall/bush ok.
and pipino, do you know if the c120 feedhorn fits this?
pipino
Back from the dead
fitting you will fit a C120..the big question how...ask the seller if he has a close picture of the lnb support so we have a look and may be advise what you can use to hold that C120 lnb..from far i can see a corotor C/KU band system ,,
garyg
garygoodger.com
The current setup would this perform at badr6?
