ITV HD Humax HDCI-2000
jobera
HUMAX 2000 hdci
spain
Hi Developers,
I am afraid to download something on my deco. Trying to download previous .fdf files all my favorites have changed.
Could be the Loader Version U4.01? (see attached TV screen image).
Jobera
jobera
HUMAX 2000 hdci
spain
Jem,
I forgot to tell you that I've the latest firmawe v10016
Jobera
Bbigfoot
Humax 5400irc
80cm Dish
Invacom 0.3 LNB
ToH 3.3 5.7.
P4 Xp home
3.2 pro.
Tyne Wear
Hi All,
Has thier been any Firmware for the Humax HDCI2000
to Enable the USB socket.
BF...
No, that's dead in the water as far as the user is concerned.
Doubt that there'll be much else as far as firmware is concerned for this model, most updates are concentrated on newer models (Freesat STB's)
Bbigfoot
Humax 5400irc
80cm Dish
Invacom 0.3 LNB
ToH 3.3 5.7.
P4 Xp home
3.2 pro.
Tyne Wear
Hi Llew,
Thanks for reply, just bought a Passion +, and a USB external HDD.
The idea was If (Humax) had Enabled the USB port, I could
had interchanged the Hard Disk.
Never mind.
BF...
developers
www.development.plus.com
Vu+ Solo 4k PVR using Enigma2, Motorised Triax 1.1m, fixed Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2 & Satlook HD
Cheshire.
Jobera
I don't know what a deco is!
I have not seen the screen you show as I have to move my box near my pc to upload files with the null modem cable. Are you using the Humax Formula program to upload the channel list?
The screen shows hdf error. The hdf files are for the firmware so if you are using the fdf channel list file with an hdf loader could that be the problem?
Jem
jobera
HUMAX 2000 hdci
spain
Hi Jem,
My deco is Humax HDCI2000 HD and I use Formula.
As I said before: The download process begins correctly and when arrives 100%, begins another process (I think is decompression process) that only arrives to the 7 % aprox. Then: [E-02] HDF Header CRC Error
Jobera
developers
Cheshire.
Jobera Hi
Do you click on "Download firmware" or "Download to STB"
Jem
jobera
HUMAX 2000 hdci
spain
Hi Jem,
Download to STB
Jobera
developers
Cheshire.
Hi jobera
As I can't reproduce the error I don't know what to suggest except as before to use the firmware update program WDN4OAK+ to try to install a different firmware and hopefully loader version in the hope that allows the channel list update, you can always update the firmware after.
Jem
jobera
HUMAX 2000 hdci
spain
Thank you Jem.
I will try to download firmware with WDN4OAK+
Jobera
marco42
Freesat Foxsat- HD
Humax
belfast
developers said:
Hi Marco42
This thread is all about the Humax HDCI 2000 for ITV settings. If that's your box read from the beginning, post 1 - if you've got the official Humax Freesat box you should be able to access it when it is broadcasting (don't hold your breath) by pressing the red button when watching ITV normally.
Jem
Hi,Thankyou for getn back to me i would like to add do i have to add software to recieve HD channels or do i have to use a null cable if i need to put in software how and were do i get it please and what all channels can i get i have not installed my freesat as yet but i would like to know before i install thanks for your help
Marco;)
developers
Cheshire.
Hi Marco42
Please add your system details to your profile. At the moment I don't know what box you have to reply.
Jem
marco42
Freesat Foxsat- HD
Humax
belfast
Hi.D; I have a humax foxsat-hd satellite hd digital box if that helps matey
From marco
developers
Cheshire.
Hi Marco
This thread is all about HDCI2000. I don't know anything about your box. I suggest you start a new thread still in Humax HD, or Freesat as you think best, where people who have your box can see it.
Jem
f.mateus
HP
PORTUGAL
Hi friends good evening for every boody, from a portuguese frind, merry christmas for all of you, well I´m the one desespered as well with a humax 2000 HDCI, soft 1.00.16 and using a diablo light 2.3 with underwold 1.48 , but I know to get the ITV HD is not necessary use a cam, but till now all I get is a black screen with a fallowing parametres freq- 11427 H 27500 2/3 pid v: (8192) pid a: (3402) and p: (3401) sid (10501) onid (59) and when I press on opt+ audio I get on a black screen Áudio Inglish but no sound of course I did follow all most the instrutions to modify and upload to the stb the modified liste of channels but til now no chance yet only black screen, as in the o,8w channels HD´s I´ve only some ones as canal+ sports HD, canal+film HD nat Geo HD Voom HD and SVT HD all the others HD´s are black screen, I had a Mvision 200 HD Combo from a friend of me and all the HD´s from 0,8w was open why??? ho :-Nooo
developers
Cheshire.
To get ITV HD I scanned for Brit Shorts frequency with a scan 11426 H 2/3. I then copied the BBC HD entry then renamed it ITV HD then changed the transponder entry (right click over BBC frequency) to the Brit Shorts 11426 H 2/3. Then change SID to 0 V PID 3401 Audio 3402 PMT 3400 PCR 3401 I just left the text and subtitle settings as BBc HD as I don't know better!
It does work if you actually follow ALL the instructions!
Jem
For the HD channels on Thor, try scanning in (for instance) 11.938H SR25000 FEC 3/4 for Canal+ Sport HD/ Film HD/ SVT HD.
There has been some frequency changes since your present channel list I suspect.
Check out _http://en.kingofsat.net/tv-0.8W.php
for latest updates.
f.mateus
HP
PORTUGAL
Ijem, thankyou for the instrutions, well I donne exatelly what you say I mean I did scanned the Brit Shorts frequecy then with formula I did change the sitings on the same line as it is in ITV HD channel with all parametrs mentioned, but like this it dont works, but as you have donne, I dont know how, you mean I´ve to copy the bbc hd line to the brit shorts and then modify it ? it´s a big confusion to me, but I will try once more! to see if I will beable to get ITV HD » about the 0,8w channels I get all of them, but they are black screen, they dont open with humax +dia*lo, but they do with Mvision 200 HD Combo with dia*lo, so I beelieve is some thing wrrong with humax soft,
thankyou friends and sorry for my improved english :) plus.
mateus
developers
Cheshire.
Hi F Mateus
Yes you have to copy the BBC HD line to a place with other 28 E channels, then change the name to ITV HD, the frequency to the same as Brit Shorts then all the parameters exactly as typed in post 2. It does work if you follow this. It will NOT work unless you amend BBC HD copied entry. There must be hidden settings.
Keep trying I'm watching a stunning picture as I type!
Jem
